I have totally reinstalled:
Incredible PBX 2027-U
Incredible PBX 2027-U 16.0.40 running on CrownCloud
Almost everything is working fine. My IAX2 extensions work great. My SIP phones receive calls just fine.
I just can't dial calls from them, internal or external. All I get is "Not Acceptable Here" on the display.
Using Legacy SIP right now.
The logs show the following:
[2025-06-13 01:04:29] VERBOSE[3307][C-0000012f] netsock2.c: Using SIP RTP TOS bits 184
245 [2025-06-13 01:04:29] VERBOSE[3307][C-0000012f] netsock2.c: Using SIP RTP CoS mark 5
246 [2025-06-13 01:04:29] ERROR[3307][C-0000012f] res_srtp.c: Failed to create srtp session on rtp instance (0x7f59a81efbc0) - cipher failure
247 [2025-06-13 01:04:29] WARNING[3307][C-0000012f] res_srtp.c: Could not set SRTP policies
248 [2025-06-13 01:04:29] WARNING[3307][C-0000012f] chan_sip.c: Failed to receive SDP offer/answer with required SRTP crypto attributes for audio
I have looked at the RTP settings under SIP settings and can't see anything obviously wrong but have been beating mh head against the wall.
Thank goodness I have an IAX2 soft phone for outbound and my calls come in to the SIP phone OK.
Any pointers on what might be wrong? I have Googled the message and most of the responses seem to center around trunks and not SIP phones.
