Email Problems: Gmail and PostFix Solutions
edisoninfo
It appears that Time Warner has now uploaded their entire list of dynamic IP's to a spam list of some sort. So almost all of the outbound emails are being rejected. The linux boxes that I use Postfix on are very easily configured to send outbound through TW's email server masquarading as a valid domain. But, the piaf boxes all default to sendmail and I just can not get the sendmail.cf, etc/hosts, hostname, etc. configured right to get email out. I tried switching them to Postfix but did not succeed there either. Any pointers?
Our strongest recommendation is to implement the Gmail Solution with SendMail. You'll never have to worry about outbound email again. :idea:
I concur with this 110% !!! In addition, you don't have to worry about your inbound e-mail not getting in if your internet ever goes down.
Seeing how sendmail is arguably the most popular mail server there is... one of my long-standing wishes is that someone could really enlighten everyone. I get sendmail to work everytime, and don't ever want to use Google for anything... just don't ask me how.
My notes on PostFix (not tested):
# Uninstall Sendmail
rpm -e --nodeps sendmail (uninstalls sendmail)
# Install Postfix
yum -y install postfix
nano /etc/postfix/main.cf
Add line relayhost = smtp.isp.com (e.g. smtp.comcast.net)
reboot
Another related question I wish I knew more of, was how to redirect to different ports (e.g. 587) and add authentication. I've come across requests for these, but have always managed to work a way around them. I just wish I knew more here...
To change ports add a :587 to the end of the hostname. Also, if you add brackets like [hostname] turns off MX lookups.
ie.
relayhost = [smtp.isp.com]:587
For authentication are you referring to outbound? Like logging into your isp with your user/pwd to send a message? Most isp's seem to be requiring that now. It is a little more difficult but not bad. The hardest part is making sure you have a version of postfix installed that supports sasl. Run postconf -a and postconf -A and you should see Cyrus listed. If not, you do not have it.
Add these lines to the postfix main.cf file
smtp_sasl_auth_enable = yes
smtp_sasl_password_maps = hash:/etc/postfix/sasldb
smtp_sasl_security_options = noanonymous
create the /etc/postfix/sasldb file and put the smtp hostname you used above, then a tab, then the username and password to log into the isp seperated by a :
ie.
smtp.isp.com <tab goes here> username : password (no spaces. It kept showing a smiley face)
Then run the command postmap sasldb and it should create a hashed version of the file called sasldb.db
Restart postfix and wha-la....
Run the command tail -f /var/log/maillog and watch for errors. Ctrl-C will get you out of it.
