return [
'release' => '0.9.62',
wget -O- https://raw.githubusercontent.com/nemerald-voip/fspbx/main/install/install-fspbx.sh | bash
tail -f /var/www/fspbx/storage/logs/laravel.log
I reinstalled yesterday. Was the .62 version not being pulled by the installer then?Great!
The above wget command is for installation only. Once installed, you need to use the update commands I posted above to update the system. Provided the initial installation went well.
Feature request for manual setting of extension password and issue report for password too long for MicroSIP softphone both added in Github.0.9.62 was released 15 hours ago, according to our release notes. It's hard to tell why you had the issue in 0.9.61. We haven't worked on the extensions page on that release as far as I know. A log would have helped. You know what to do next time.
I'm taking a note about MicroSIP not accepting a long password. That's good to know. Could you open a GitHub request so we can address it appropriately?
You need to follow the instructions. You made changes to files in the directory that git is tracking. You need to commit the changes to that file or stash them so they are ignored. There is no real error here, just got doing its job.@pbxgeek: We get a git error running the pull command:
Code:git pull Updating 0ea1add0..a74e7c02 error: Your local changes to the following files would be overwritten by merge: resources/lua/cnam_lookup.lua Please commit your changes or stash them before you merge. Aborting
Also, running the current version of .62, creating a domain does not work. You can add the domain under domains but it is never made available when you click on the domain in the upper right corner of the screen. The system does not recognize what was created.@pbxgeek: We get a git error running the pull command:
@wardmundy, yes, just git stash and you will be able to proceed. @Samot is correct. Git is just doing what it is supposed to do.@pbxgeek: We get a git error running the pull command:
nemerald-voip left a comment (nemerald-voip/fspbx#165)
@kenn10 @gary-clarke You can now set custom SIP passwords for extensions in version 0.9.63
Live Chat
Video Conferencing
Check your inbox!
