SOLVED fwconsole reload error
islandtech
Wassamassaw
Crown Cloud had network issues in the Miami server node
when service was restored I'm getting this error: Unknown Error. Please Run: fwconsole reload --verbose
Reload Started
In DB_Helper.class.php line 174:
  [PDOException (HY000)]
  SQLSTATE[HY000]: General error: 1712 Index kvstore_FreePBX_modules_Amd is corrupted
Exception trace:
  at /var/www/html/admin/libraries/BMO/DB_Helper.class.php:174
 PDOStatement->execute() at /var/www/html/admin/libraries/BMO/DB_Helper.class.php:174
 FreePBX\DB_Helper->getConfig() at /var/www/html/admin/modules/amd/Amd.class.php:86
 FreePBX\modules\Amd->getAmdSettings() at /var/www/html/admin/modules/amd/Amd.class.php:103
 FreePBX\modules\Amd->genConfig() at /var/www/html/admin/libraries/BMO/FileHooks.class.php:99
 FreePBX\FileHooks->processNewHooks() at /var/www/html/admin/libraries/BMO/FileHooks.class.php:28
 FreePBX\FileHooks->processFileHooks() at /var/www/html/admin/libraries/Console/Reload.class.php:340
 FreePBX\Console\Command\Reload->reload() at /var/www/html/admin/libraries/Console/Reload.class.php:95
 FreePBX\Console\Command\Reload->execute() at /var/www/html/admin/libraries/Composer/vendor/symfony/console/Command/Command.php:312
 Symfony\Component\Console\Command\Command->run() at /var/www/html/admin/libraries/Composer/vendor/symfony/console/Application.php:1022
 Symfony\Component\Console\Application->doRunCommand() at /var/www/html/admin/libraries/Composer/vendor/symfony/console/Application.php:314
 Symfony\Component\Console\Application->doRun() at /var/www/html/admin/libraries/Composer/vendor/symfony/console/Application.php:168
 Symfony\Component\Console\Application->run() at /var/lib/asterisk/bin/fwconsole:163
In the past running fwconsole chown would fix it
I tried all google suggestions
I'll follow up with gemini later
system is usable till closing time
CrownCloud provides free snapshot backups. Do you have one?? A restore would be the easy solution.
yes I have a snapshot
no I didn't restore
Gemini suggested disabling the AMD module
I uninstalled it (not using any of its functions)
Restarted asterisk no errors
ro-fi
