TIPS Need help setting up ov500 VoIP Billing + Kamailio + Freeswitch
Did you install the centos or debian version?
Looks like the ov500 installer for CentOS 7 fails, going to check the Debian 11 installed and get back to you
OV500 is not really all that great, and seems to be abandonware. Also, CentOS 7 went EOL last year
Agreed, was great when it worked but ASTPP seems to have taken over.
Features list are as below...
  • Prepaid / Postpaid Billing
  • GUI design in CodeIgniter Web Framework
  • Portal developed in HMVC architecture
  • Used opensource Mariadb Database
  • Kamailio, RTPProxy and Freeswitch based Solution
  • High scalable solution (Solution fit for single-server architecture and multi-server architecture based on business needs.)
  • High CPS and CC support.
  • Easy to Manage
  • Fit for Wholesale, call center traffic, retail traffic as Class-4 Switch and billing. The residential solution as Class-5 switch and billing
  • IP and SIP User, Dialprefix and Caller ID-based authentication
  • Multi-level Reseller account Management
  • DID billing
  • Smart and dynamic routing
  • Tariff Management
  • The integrated online payment process option
  • Monitoring & Reporting
and many more
Release Notes​
3.0.0 (04/01/2026)​
You may want to wait until ASTPP 7 community is released. They said everything has been updated so you can run it on the likes of Debian 12. Was supposed to be released in March, but they have been late on a lot of things.
install script broke in the same place, so it's not me.
Verizon 7 has not been released and only supports Cents OS 7 and Debian 11.
Sunnysideup
