QUESTION fspbx install
islandtech
Wassamassaw
Following the icing on the cake guide: Changing the SIP Port for Phone Registrations
Step 9. Restart IPtables: iptables-restart
command not found
should the command include the hyphen
Its /usr/local/sbin/iptabes-restart since the full path is required on FS PBX. If that is added to $PATH on the root login, you run into problems with some of the FS PBX or FreeSwitch stuff.
Actually, on my system, the /usr/local/sbin is in my $PATH already and that command works.
Perhaps if you log out and back in, your $PATH will be updated and then iptables-restart will work for you.
~# echo $PATH
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
lahensd
