Fax with Debian 13 with Asterisk 22
If all you need is inbound faxing (or that's a priority right now) you do this:
1. Go into User Manager and create a user
2. Under User Settings tab give the user an email address
3. Under Fax tab enable Faxing for the user
4. In Inbound Routes pick the number that will receive the fax
5. In the Fax tab turn on fax detection, set the mode to SIP and then set the Fax Destination to "Fax Recipient" and select the user.
You are now receiving inbound faxes and the methods between what FreePBX does and the Incredible PBX article are how the fax is handled **after receiving** i.e. how it is stored (or not), tiff to pdf conversion and the emailing process.
have not tried yet, still working on installintg the new IPBX.........question........................for ward or Kenn10..........ward was referring to IPBX 2026 originally, but ward's article for installing FAX referred to IPBX 2027 for debian 13, does it matter which debian 13 version I installl? 2026 or 2027 for the FAX installation?
Joe, 2026 is the latest version and runs on Debian-13. IncrediblePBX-2027 is older and Debian-12 will be expiring soon. If you look at what @Samot posted above, you can use the built-in FAX receiving function of FreePBX. That lets you receive faxes. That is a FreePBX function and should work on FreePBX-17 on IncrediblePBX-2026.
As to the IncredibleFax working with IncrediblePBX-2026, I don't think anyone has tried to use Ward's solution from IncrediblePBX-2027. I haven't heard anyone so if you want to give it a try, you can be our Guinea pig. :eek:
ok thanks kenn! hope you are enjoying the soccer! we in the states are playing this wednesday, pretty exciting. in your opinion...................i am now using vitalpbx 3 for my office, works great! but you know me, i like to tinker and (eventually break things, LOL) and i have been running IPBX for a long time (Incredible PBX 15.0.38 'Incredible PBX PUBLIC') but since it does not have a queue caller callback module, this is why i use vital pbx, as it does. I have been reluctant to upgrade to VPBX 4, since i have sooooooo much work and time invested in VPBX 3 with all ward's extras and mods, that I am afraid I will not be able to get VPBX 4 up to speed as I am now with VPBX 3, but I divest.......................Im just getting a bit board and came up with the idea if IPBX 2026 but since no queue callback, maybe i should attempt VPBX 4? your thoughts?
thanks SAMOT!! you, kenn and ward are the bestttttttttttttttttttttttttttttttttt
lluis.riera
