RECOMMENDATIONS Skip LightSail for Incredible PBX!
w1ve
I trired a 2 vPu, 4 GB Ram LightSail instance. At first, it worked perfectly. However, the burst CPU Availability can vary all over the place, and suddenly you get stuttering. I switched to an EC2 g7.large insstance, with 12.5GBps networking, and it is flawless. This is for a short-term special project in the UK. Using UK DIDs from voip.ms and Bulkvs.com, and working flawlessly.
Which version of LightSail did you use? How much traffic/resources is the system using? You've provided no real details to support your claim and your solution is sounding like overkill.
You replaced a $24-ish month VM with $1,800/month VM. Yeah...gonna be some differences.
skytelecom
