TIPS How to make extensions auto-select correct transport/media_address without editing each one?
silimms
Environment:
IncrediblePBX (FreePBX) / Asterisk 22.11.0, chan_pjsip
Server with multiple network interfaces:
192.168.22.209 (eth0) — external-facing NIC, port forwarding for remote/roaming extensions + IAX2
192.168.23.209 (eth1) — internal VLAN, all internal phones live here (isolated, no internet access by design)
10.0.10.10 — SIP trunk Providers
All PJSIP UDP transports bound on port 7666 (per-IP)
SIP trunk Providers on 5060
Problem:
I have a multi-homed FreePBX / Asterisk (chan_pjsip) server. When an extension's transport is left empty, Asterisk auto-selects a transport and, in this multi-homed setup, often picks the wrong one. As a result the media_address ends up as the wrong interface IP — e.g. a phone registered from 192.168.23.69 gets media_address = 192.168.22.209.
What I've found works (but only per-extension):
I've found two ways to fix it, but each one has to be done per extension:
Option 1 — edit pjsip.endpoint_custom_post.conf:
[<extension number>](+)
media_address=192.168.23.9
Option 2 — modify the extension (GUI Advanced tab):
transport = 192.168.23.209-udp (the correct interface)
media_use_received_transport = yes
My question:
Is there a way to make this happen globally / automatically for all extensions, instead of editing every single extension (via the GUI Advanced tab or pjsip.endpoint_custom_post.conf)?
Yes, one line per transport, no per-extension edits. What you are fighting is how "Auto" behaves in 22.11: when the endpoint has no transport, a PBX-originated request (INVITE, OPTIONS) is sent on whichever UDP transport pjsip finds first, not on the one the phone registered through. Responses to the phone's own INVITEs already go back on the arrival transport, which is why it only "often" fails.
The global fix is the transport option symmetric_transport. With it set, every request that arrives on that transport gets the transport name stored in the contact URI as an x-ast-txp parameter at registration, and any later outgoing request to that contact uses the same transport as long as the endpoint's transport is empty and the contact host is an IP. FreePBX includes pjsip.transports_custom_post.conf immediately after its generated transports, so append it there once:
192.168.22.209-udp symmetric_transport=yes
192.168.23.209-udp symmetric_transport=yes
10.0.10.10-udp symmetric_transport=yes
Use your actual transport section names from pjsip show transports. Reload and make the phones re-register, since the tag is written at REGISTER time. pjsip show contacts should then show x-ast-txp=192.168.23.209-udp on the internal phones, with the endpoint's Transport still on Auto.
For the media address, leave it blank on every extension. Without media_address the SDP is first built with the host's default address and the outbound filter rewrites the c= line to the interface the OS routes to that phone, keeping port 7666; RTP is bound to 0.0.0.0 so it receives on any interface. Setting media_address per extension is what switches that rewrite off. Two things must be true for it to hold: Local Networks in SIP Settings lists all three subnets (192.168.22.0/24, 192.168.23.0/24, 10.0.10.0/24) so the External Address rewrite never applies to an internal destination, and the routing table sends each phone subnet out of the right interface, with static routes via eth1 if any internal phones sit behind the VLAN router rather than on 192.168.23.0/24.
Your Option 2 works because of the transport line; media_use_received_transport is about honouring the RTP profile from the offer, not interfaces, so drop it.
If after this an internal phone still gets c=192.168.22.209, post the startup line "Local IPv4 address determined to be" and the output of pjsip show transport 192.168.23.209-udp, and it becomes a two-line answer.
You can set a default transport per endpoint group using the transport parameter in a template that all extensions inherit from. In FreePBX that usually means editing the endpoint template rather than each extension individually.
Environment:
Problem:
My question:
Following your method, we still had some calls with no audio. In the end, the fix was:
Modify pjsip.transports_custom_post.conf as follows:
[10.0.10.10-udp]
type=transport
protocol=udp
bind=10.0.10.10:5060
allow_reload=no
Then in SIP Settings, just select udp-0.0.0.0 - All and fill in the External IP Address and Port to Listen On.
But the extension’s phone also needs NAT specifically enabled.
