Widespread PHP Flaw
They are affected but I would hope you don't have your web interfaces exposed to the internet . . . like yikes.
Almost every website in the world has web interfaces exposed to the internet, non ?
This website does (Xenforo), Wordpress does. 70% of all websites in the world are php.
For those using older distros which are EOL there are couple of which can be done:
Recompile PHP with this patch:
The PHP project lists configuration measures that reduce exposure but, in their own words, do not make the installation safe. Treat this as a temporary step until you can update PHP, not as a fix:
  • session.upload_progress.enabled = 0
  • memory_limit = -1 (set so it cannot be overridden per application; see the caution below)
  • post_max_size kept low (see the ASTPP note below)
  • upload_max_filesize kept below post_max_size
Apply these in php.ini or your FPM pool configuration, not with ini_set() or .user.ini, and restart every PHP worker afterwards.
Two cautions specific to ASTPP, please read before applying:
  • ASTPP uses file uploads for rate card and DID imports. If you set post_max_size too low, large imports will fail. The PHP advisory suggests 32M where uploads are needed. Set it based on your largest import, and test an import after applying.
  • memory_limit = -1 removes the PHP memory ceiling. This is the PHP-recommended mitigation, but it means a single request is no longer capped, which is an availability consideration on a production server. If you can, use an operating-system level limit (container or cgroup) as the safety boundary instead, and do not use RLIMIT_AS or RLIMIT_DATA.
Always back up your existing php.ini before changing it.
Yes, but your Freepbx based ones should never be exposed to the internet at large. Ever. Its' just not secure enough.
That's why a whitelist only IncrediblePBX stock install is really not affected by this.
That is definitely something worth bragging about. I think PIAF was very security focused and that tradition has carried on.
Not inherently, no, split DNS just basically means public and private resolve to different IP's.
So, IncrediblePBX doesn't need that because ... ? Why does 3CX essentially force it on people ? Security ? Protect their licenses ?
Ivozprovider recommend it too
I'm not sure. Split DNS isn't inherently connected to PBX services really. It's a configuration used in certain network topologies that require it to use private/public network layouts. If your 3cx server is on an internal network (192.168.x.x or 10.x.x.x. for example, there are a couple others but those are commonly used), and you also want to expose it externally, you'll need an internal DNS server that resolves to 10.x.x.x for the phones inside the network, or you have to hard code the IP, and an external one that resolves to whatever the external IP is your carrier/ISP provides. I'm not familiar with 3cx to a level that would allow me to comment on why it's required per se, but I would imagine it's because many people set up on premises 3cx servers that they also expose to the outside world in order to facilitate connections when on the road or at home, that kind of thing, and so by default they have decided it's easier to support if you insist on this topology for consistency. But that's entirely conjecture.
hostgsm
