ALERT VitalPBX & FusionPBX Security Update
If you're running FusionPBX or FS PBX, you probably also need to update NGINX with the steps above.
It looks like Debian-13 is OK.
#dpkg-query -W nginx nginx-common
nginx   1.26.3-3+deb13u10
nginx-common    1.26.3-3+deb13u10
Here's another hack for anyone who has the mini travel routers from GL.iNet:
On November 20, 2026, GL.iNet identified a security vulnerability in our cloud remote management services. An unauthorized party exploited this vulnerability to access and install malicious software on a subset of GL.iNet routers and KVM devices.
What we have done
- Closed the vulnerability in our cloud services upon discovery.
- Implemented corrective measures to address the identified security issue on affected devices.
- Engaged in an ongoing investigation of the incident.
What we will do next
- Firmware update: We are preparing an updated firmware release with additional security protections and will make it available as soon as possible.
- Direct notification: We will individually notify each affected customer by email at the address associated with their cloud account, with specific guidance for their devices.
- Investigation: We are investigating the full scope of the incident, including any potential impact on computers connected to affected KVM devices.
- Updates: We will update this notice as new information becomes available.
Not sure if your device was affected?
Please contact our technical support team at [email protected]. We will help you check your device.
What we recommend
KVM users
1. Perform a factory reset by pressing and holding the Reset button for approximately 10 seconds while the device is powered on, then release it. Set up your device again. For additional instructions, refer to the KVM Factory Reset Guide.
2. As a precaution, check the computer connected to the KVM device for signs of unauthorized activity, such as:
- Unfamiliar programs, browser extensions, or user accounts
- Unexpected startup items or scheduled tasks
- Changed system settings or unusual network activity
3. We also recommend running a full scan with up-to-date security software. If you find anything suspicious, change the passwords for accounts used on that computer and contact us.
4. Install the updated firmware as soon as it is released.
Router users
1. Perform a factory reset by pressing and holding the Reset button for 10 seconds after the router has fully started, then release it. Set up your router again. For additional instructions, refer to the Router Factory Reset Guide .
2. Install the updated firmware as soon as it is released.
Contact
For questions, please contact [email protected].
To report a security issue, contact [email protected].
We apologize for the concern this may cause and are committed to keeping you informed.
if they do not contact you directly to confirm you are affected, you do not need to reset your router
fibrewire
