Web based Docker SIP Client
mzac23
After finding that my old school Bria client didn’t work on iOS 27 anymore, I had an idea that I could write a new iOS app but that is long and only supports iOS. Then I thought I could probably get claude to make a web based version. After about a day of work going back and forth I had a working POC and now after 2 days I’ve released v1.0.0 of DialDeck which is free and open source on Github.
It is a docker/kubernetes container that runs on amd64 or arm64. It has a self contained Asterisk instance that is configured through the DialDeck gui that connects you to a backend PBX using SIP and allows you to place and receive audio and videos calls through the browser on a computer or a phone so it is truly cross platform.
It supports WebTRC on the web interface and Opus and G711/G722 on the backend. What’s nice is you can host this in your homelab or even in the cloud if you want, the ideas are quite up to you what you want to do with it.
To be transparent yes I did use Claude to write the code, I would have never been able to figure it out on my own, but it actually does work and sends no telemetry or anything. Feel free to read the privacy docs or even audit it yourself.
I think this type of tool can be quite interesting and with community support & ideas can grow into something quite powerful.
This might be a good tool to also list on the wiki page under soft clients, but I'm not sure how to get it listed there.
Interesting. What were your reasons why you chose to embed an instance of asterisk inside the SIP client web softphone docker container?
Because it just works and is easy to configure, that simple ;)
And the asterisk sits between the web client and the real pbx in the backend. In this case asterisk inside docker is not acting as a PBX but acting as a proxy in a sense to do the transcoding between SIP and WebRTC.
Latest Posts
mzac23
