so lately I have been having a problem with this module and my cell phone. it appears to "time out" while attempting to dial out. however i am able to use this same trunk for follow me and other functions that do end up dialing out for me. however if I use Joe service it works fine.
so I have posted my CLI below with the hopes that someone can spot something that I can't and push me in the right direction. I am also wondering if there is a way to specify what trunk to use for this module.
I should mention that it appears to time out after a very short amount of time about 5 seconds which is very short it seems.
thanks
nathan
-- Called MyTrunkL1/6165551212
== Spawn extension (macro-dialout-trunk, s, 19) exited non-zero on 'Local/6165551212@from-internal-806f,2' in macro 'dialout-trunk'
-- Executing [h@macro-dialout-trunk:1] Macro("Local/6165551212@from-internal-806f,2", "hangupcall|") in new stack
-- Executing [s@macro-hangupcall:1] ResetCDR("Local/6165551212@from-internal-806f,2", "vw") in new stack
-- Executing [s@macro-hangupcall:2] NoCDR("Local/6165551212@from-internal-806f,2", "") in new stack
-- Executing [s@macro-hangupcall:3] GotoIf("Local/6165551212@from-internal-806f,2", "1?skiprg") in new stack
-- Goto (macro-hangupcall,s,6)
-- Executing [s@macro-hangupcall:6] GotoIf("Local/6165551212@from-internal-806f,2", "1?skipblkvm") in new stack
-- Goto (macro-hangupcall,s,9)
-- Executing [s@macro-hangupcall:9] GotoIf("Local/6165551212@from-internal-806f,2", "1?theend") in new stack
-- Goto (macro-hangupcall,s,11)
-- Executing [s@macro-hangupcall:11] Hangup("Local/6165551212@from-internal-806f,2", "") in new stack
== Spawn extension (macro-hangupcall, s, 11) exited non-zero on 'Local/6165551212@from-internal-806f,2' in macro 'hangupcall'
-- Attempting call on Local/6165551212@from-internal for application AGI(wakeconfirm.php) (Retry 2)
-- Executing [6165551212@from-internal:1] Macro("Local/6165551212@from-internal-a335,2", "user-callerid|SKIPTTL|") in new stack
-- Executing [s@macro-user-callerid:1] Set("Local/6165551212@from-internal-a335,2", "AMPUSER=*68") in new stack
-- Executing [s@macro-user-callerid:2] GotoIf("Local/6165551212@from-internal-a335,2", "1?report") in new stack
-- Goto (macro-user-callerid,s,11)
-- Executing [s@macro-user-callerid:11] GotoIf("Local/6165551212@from-internal-a335,2", "1?continue") in new stack
-- Goto (macro-user-callerid,s,20)
-- Executing [s@macro-user-callerid:20] NoOp("Local/6165551212@from-internal-a335,2", "Using CallerID "Wake Up Calls" <*68>") in new stack
-- Executing [6165551212@from-internal:2] Set("Local/6165551212@from-internal-a335,2", "_NODEST=") in new stack
-- Executing [6165551212@from-internal:3] Macro("Local/6165551212@from-internal-a335,2", "record-enable|*68|OUT|") in new stack
-- Executing [s@macro-record-enable:1] GotoIf("Local/6165551212@from-internal-a335,2", "1?check") in new stack
-- Goto (macro-record-enable,s,4)
-- Executing [s@macro-record-enable:4] AGI("Local/6165551212@from-internal-a335,2", "recordingcheck|20100101-195832|1262393912.475") in new stack
-- Launched AGI Script /var/lib/asterisk/agi-bin/recordingcheck
recordingcheck|20100101-195832|1262393912.475: No AMPUSER db entry for *68. Not recording
-- AGI Script recordingcheck completed, returning 0
-- Executing [s@macro-record-enable:5] MacroExit("Local/6165551212@from-internal-a335,2", "") in new stack
-- Executing [6165551212@from-internal:4] Macro("Local/6165551212@from-internal-a335,2", "dialout-trunk|22|6165551212||") in new stack
-- Executing [s@macro-dialout-trunk:1] Set("Local/6165551212@from-internal-a335,2", "DIAL_TRUNK=22") in new stack
-- Executing [s@macro-dialout-trunk:2] GosubIf("Local/6165551212@from-internal-a335,2", "0?sub-pincheck|s|1") in new stack
-- Executing [s@macro-dialout-trunk:3] GotoIf("Local/6165551212@from-internal-a335,2", "0?disabletrunk|1") in new stack
-- Executing [s@macro-dialout-trunk:4] Set("Local/6165551212@from-internal-a335,2", "DIAL_NUMBER=6165551212") in new stack
-- Executing [s@macro-dialout-trunk:5] Set("Local/6165551212@from-internal-a335,2", "DIAL_TRUNK_OPTIONS=Tt") in new stack
-- Executing [s@macro-dialout-trunk:6] Set("Local/6165551212@from-internal-a335,2", "OUTBOUND_GROUP=OUT_22") in new stack
-- Executing [s@macro-dialout-trunk:7] GotoIf("Local/6165551212@from-internal-a335,2", "0?nomax") in new stack
-- Executing [s@macro-dialout-trunk:8] GotoIf("Local/6165551212@from-internal-a335,2", "0?chanfull") in new stack
-- Executing [s@macro-dialout-trunk:9] GotoIf("Local/6165551212@from-internal-a335,2", "0?skipoutcid") in new stack
-- Executing [s@macro-dialout-trunk:10] Set("Local/6165551212@from-internal-a335,2", "DIAL_TRUNK_OPTIONS=Tt") in new stack
-- Executing [s@macro-dialout-trunk:11] Macro("Local/6165551212@from-internal-a335,2", "outbound-callerid|22") in new stack
-- Executing [s@macro-outbound-callerid:1] ExecIf("Local/6165551212@from-internal-a335,2", "0|SetCallerPres|") in new stack
-- Executing [s@macro-outbound-callerid:2] ExecIf("Local/6165551212@from-internal-a335,2", "1|Set|REALCALLERIDNUM=*68") in new stack
-- Executing [s@macro-outbound-callerid:3] GotoIf("Local/6165551212@from-internal-a335,2", "1?normcid") in new stack
-- Goto (macro-outbound-callerid,s,6)
-- Executing [s@macro-outbound-callerid:6] Set("Local/6165551212@from-internal-a335,2", "USEROUTCID=") in new stack
-- Executing [s@macro-outbound-callerid:7] Set("Local/6165551212@from-internal-a335,2", "EMERGENCYCID=") in new stack
-- Executing [s@macro-outbound-callerid:8] Set("Local/6165551212@from-internal-a335,2", "TRUNKOUTCID="CompleteTechSolutions"<6162240100>") in new stack
-- Executing [s@macro-outbound-callerid:9] GotoIf("Local/6165551212@from-internal-a335,2", "1?trunkcid") in new stack
-- Goto (macro-outbound-callerid,s,12)
-- Executing [s@macro-outbound-callerid:12] ExecIf("Local/6165551212@from-internal-a335,2", "1|Set|CALLERID(all)=CompleteTechSolutions<6162240100>") in new stack
-- Executing [s@macro-outbound-callerid:13] ExecIf("Local/6165551212@from-internal-a335,2", "0|Set|CALLERID(all)=") in new stack
-- Executing [s@macro-outbound-callerid:14] ExecIf("Local/6165551212@from-internal-a335,2", "0|SetCallerPres|prohib_passed_screen") in new stack
-- Executing [s@macro-dialout-trunk:12] ExecIf("Local/6165551212@from-internal-a335,2", "1|AGI|fixlocalprefix") in new stack
-- Launched AGI Script /var/lib/asterisk/agi-bin/fixlocalprefix
-- AGI Script fixlocalprefix completed, returning 0
-- Executing [s@macro-dialout-trunk:13] Set("Local/6165551212@from-internal-a335,2", "OUTNUM=6165551212") in new stack
-- Executing [s@macro-dialout-trunk:14] Set("Local/6165551212@from-internal-a335,2", "custom=SIP/MagicJackL1") in new stack
-- Executing [s@macro-dialout-trunk:15] ExecIf("Local/6165551212@from-internal-a335,2", "0|Set|DIAL_TRUNK_OPTIONS=M(setmusic^)Tt") in new stack
-- Executing [s@macro-dialout-trunk:16] Macro("Local/6165551212@from-internal-a335,2", "dialout-trunk-predial-hook|") in new stack
-- Executing [s@macro-dialout-trunk-predial-hook:1] MacroExit("Local/6165551212@from-internal-a335,2", "") in new stack
-- Executing [s@macro-dialout-trunk:17] GotoIf("Local/6165551212@from-internal-a335,2", "0?bypass|1") in new stack
-- Executing [s@macro-dialout-trunk:18] GotoIf("Local/6165551212@from-internal-a335,2", "0?customtrunk") in new stack
-- Executing [s@macro-dialout-trunk:19] Dial("Local/6165551212@from-internal-a335,2", "SIP/MagicJackL1/6165551212|300|Tt") in new stack
== Spawn extension (macro-dialout-trunk, s, 19) exited non-zero on 'Local/6165551212@from-internal-a335,2' in macro 'dialout-trunk'
-- Executing [h@macro-dialout-trunk:1] Macro("Local/6165551212@from-internal-a335,2", "hangupcall|") in new stack
-- Executing [s@macro-hangupcall:1] ResetCDR("Local/6165551212@from-internal-a335,2", "vw") in new stack
-- Executing [s@macro-hangupcall:2] NoCDR("Local/6165551212@from-internal-a335,2", "") in new stack
-- Executing [s@macro-hangupcall:3] GotoIf("Local/6165551212@from-internal-a335,2", "1?skiprg") in new stack
-- Executing [s@macro-hangupcall:6] GotoIf("Local/6165551212@from-internal-a335,2", "1?skipblkvm") in new stack
-- Executing [s@macro-hangupcall:9] GotoIf("Local/6165551212@from-internal-a335,2", "1?theend") in new stack
-- Executing [s@macro-hangupcall:11] Hangup("Local/6165551212@from-internal-a335,2", "") in new stack
== Spawn extension (macro-hangupcall, s, 11) exited non-zero on 'Local/6165551212@from-internal-a335,2' in macro 'hangupcall'
