PiaF Menu Configuration Not Working
jquintana
No matter what I select in the menu configuration under the admin section, nothing changes.
I few days ago I added the SugarCRM option and I lost the Webmin option.
Now, no matter what I select nothing changes.
What did I break and how can I fix it?
Thanks!
To access webmin:
http://<ip address>:9001
I believe that you can access FreePBX by:
http://<ip address>/admin/config.php
I can access both, but they are just not in my "Admin Panel".
your hostname is not resolving - webmin will not showup unless your hostname resolves to a ip address
I have double-checked my DNS settings and everything is ok.
I am able to ping the hostname from the PiaF server as well as from other workstations.
:banghead:
Have you checked the menu configuration icon to see if webmin has been delected?
In /var/www/html/welcome/.htindex.cfg do you have this line? This is the Admin menu config file.
4,webmin,http://$host:9001/,Linux<br/>Webmin,ico_webmin.png
Have you run update-scripts, update-fixes?
What does the Linux command prompt "status" command indicate? If webmin isn't showing up then it could be a network problem after all as MyKroFt stated.
Lastly, have you checked Webmin's log at /var/webmin/webmin.log for clues? I wonder if running passwd-master would help?
This is the contents of my .htindex.cfg file:
1,recordings,./recordings,Voicemail & Recordings,ico_recordings.png
1,panel,./panel,Flash Operator Panel,ico_fop.png
1,meetme,./meetme,MeetMe Conference,ico_meetme.png
2,asteridex,./asteridex4,Nerd Vittles AsteriDex,ico_asteridex.png
2,asterimind,./reminders,Nerd Vittles Reminders,ico_asterimind.png
2,awstats,http://$host/cgi-bin/awstats.pl?config=PBXinaFlash,Web Statistics AWs$
2,crm,./crm,Sugar CRM,ico_crm.png
3,a2billing,./A2Billing_UI,A2Billing Administration,ico_a2badmin.png
3,a2customer,./A2BCustomer_UI,A2Billing Customer,ico_a2bcust.png
4,admin,./admin,FreePBX Administration,ico_freepbx.png
4,menu,./config.php,Menu Configuration,ico_ksc-menu.png
I am pretty sure I ran update-scripts and update-fixes already.
This is what "status" returns:
Status - 1.7.6 released on 071010
*            PBX in a Flash SILVER Daemon Status                   *
* Asterisk  * ONLINE  * Dahdi     * ONLINE  * MySQL      * ONLINE  *
* SSH       * ONLINE  * Apache    * ONLINE  * Iptables   * ONLINE  *
* Fail2ban  * ONLINE  * IP Connect* ONLINE  * Ip6tables  * OFFLINE *
* BlueTooth * ONLINE  * Hidd      * ONLINE  * NTPD       * ONLINE  *
* Sendmail  * ONLINE  * Samba     * ONLINE  * Webmin     * ONLINE  *
* Ethernet0 * ONLINE  * Ethernet1 *   N/A   * Wlan0      *   N/A   *
* PBX in a Flash Version   : 1.7.5.5
* FreePBX Version          : 2.6.0.2
* Running Asterisk Version : Asterisk 1.4.33
* Asterisk Source Version  : 1.4.33
* Dahdi Source Version     : 2.3.0.1+2.3.0
* Libpri Source Version    : 1.4.11.3
* Addons Source Version    : 1.4.11
linserv.five-fifteen.local on 10.0.0.13 - eth0
CentOS release 5.5 (Final) :32 Bit Kernel: 2.6.18-194.3.1.el5
I would run update-scripts, update-fixes and passwd-master again. It won't hurt anything, hopefully fix what's broken.
$host is not being populated with your machine ip.address.....
you could force $host in:
to localhost, then it should not have to resolv
also do you have the following at the top of your /etc/hosts file:
# Do not remove the following line, or various programs
# that require network functionality will fail.
127.0.0.1               pbx.local pbx localhost.localdomain localhost
::1             localhost6.localdomain6 localhost6
er no localhost wont work either, your machine on which your browser is running will attempt to contact itself - 127.0.0.1 etc.
Need to figure out why $host is not populated
here are the revelant lines in index.php that is populating $host:
     31 error_reporting(E_ALL ^ E_NOTICE);
     32 $host = $_SERVER['HTTP_HOST'];
     33 if (strpos($host,":")>0) :
     34         $host = substr($host,0,strpos($host,":")) ;
     35 endif ;
now we need to figure out what your web server is sending back for http_host......
it should come back with whatever address you are contacting your server as.
my box is on 192.168.0.2, and if use http://192.168.0.2, $host comes back at 192.168.0.2, i also have a alias of pbx-glacer to my hamachi ip
so again, something dns wise is not resolving and its timeing out
when you boot, do you get a warning when apache starts up that it cant figure out your FQDN?
I noticed I was using a different hostname in httpd.conf than that of my server.
Hostname is linserv.five-fifteen.local
httpd.conf was set to piaf.five-fifteen.local
After I set the httpd.conf to linserv.five-fifteen.local and restarted apache the webmin button appeared again.
Thanks to all who have helped!
