luckman212
- Jul 7, 2010
- 272
- 0
ok well maybe it's worth another shot-- can anyone tell me where to look as far as setting/resetting the login/password for avantfax?
I am having the same problem as this guy in that I can't log in to my Avantfax UI. I had this working on my old box, and I had the same problem, too, but I can't remember for the life of me what I did. Whenever I try to log on to Avantfax, I get:
And no matter how many times I reset the password or type in the new password, I can't get in.
Running A-Fax 3.3.3, 1.7.5.5.2 Silver install.
hi Joe, is there any news about whether hylafax 6.x could be made to work with this script? just curious since it was a year ago...I see that hylafax-6.0.3-1 is now out, maybe it is time to revisit the script.
If you reread the the original posts, it should be clear how to do this.
I have been scratching my head on this one. turns out I was managing the GUI from two different workstations and would only accept a "re-login" from same machine. I have found two fixes.
1) goto original managing browser and log-off.
2) restart web server #>service httpd restart
notice it says maint as the username in the error message even though we both know you put in admin in there.
I had the same problem of not being able to login to Avantfax. I found this solution on the Avanfax site:
Try running this statement in your AvantFAX database to create the 'maint' admin user with password "password":
INSERT INTO UserAccount (name, username, password, wasreset, email, is_admin, language, acc_enabled, any_modem, superuser) VALUES ('Trixbox Admin', 'maint', '5f4dcc3b5aa765d61d8327deb882cf99', TRUE, 'root@localhost', TRUE, 'en', TRUE, TRUE, TRUE);"
are you sure about that? I haven't been following the recent posts too closely, but I though with the most recent versions that this wasn't an issue anymore? I hardly ever receive any faxes so I really don't even have a good way of testing this.Just remember that with 1.8.x, you cant have fax detect, rather you have to use a dedicated DID
Live Chat
Video Conferencing
Check your inbox!
