completetech
- Apr 17, 2009
- 829
- 9
Looking to see if there is any sort of add on for incredible PBX that can do fax back. i.e. call into system press option (or use separate DID) possibly select an option for a certain "file" and have it fax back to the DID you are calling from, or even better prompt for the option to send it to a number.
Anything even remotely close to this around. I tried to google and look on the forum and either I am an idiot and do not know the correct search terms or I couldn't find it.
Thanks,
Nathan
Thanks,
Nathan
