NO JOY Can't call paging group
Great idea. It says install available locally. Is there way I can re-download it online?
To test if its a Yealink specific issue, try to page an extension that isn't a Yealink phone.
If the call isn't making it to the page group it shouldn't matter what kind of phone. I would say differently if the call went through but the phones didn't auto answer.
Yes rossiv is correct the call isn't getting passed the page group. I also tried adding our non-Yealink overhead loud speaker to the group & got the same thing, but I can call the speaker just fine.
lgaetz I see the "Probation Passed...." message on my box too for most if not all calls. I am really clueless why it's not working - but I agree - I think trying a different extension would be something good to try.
OK here are the logs with different extinctions. I tired 700 & 201 calling from 224.
When I switched the extension in the page group it generated a lot of info in the log, I've saved this as a .txt file as it was to big to screen shot. There where some errors & warning in it so maybe it has something to do with this issue.
  • Paging log.txt
    Paging log.txt
Well, there's no call in the TXT that I saw - just Asterisk reloading. BUT what I did see was the page group (700) was in deed created and recognized by Asterisk.
-- Added extension '700' priority 1 to ext-paging
    -- Added extension '700' priority -1 to ext-paging
    -- Registered extension context 'app-pagegroups'; registrar: pbx_config
    -- merging incls/swits/igpats from old(app-pagegroups) to new(app-pagegroups) context, registrar = pbx_ael
    -- Including context 'app-pagegroups-custom' in context 'app-pagegroups'
    -- Added extension '700' priority 1 to app-pagegroups
    -- Added extension '700' priority 2 to app-pagegroups
    -- Added extension '700' priority 3 to app-pagegroups
    -- Added extension '700' priority 4 to app-pagegroups
    -- Added extension '700' priority 5 to app-pagegroups
    -- Added extension '700' priority 6 to app-pagegroups
    -- Added extension '700' priority 7 to app-pagegroups
    -- Added extension '700' priority 8 to app-pagegroups
    -- Added extension '700' priority 9 to app-pagegroups
    -- Added extension '700' priority 10 to app-pagegroups
    -- Added extension '700' priority 11 to app-pagegroups
    -- Added extension '700' priority 12 to app-pagegroups
    -- Added extension '700' priority 13 to app-pagegroups
    -- Added extension '700' priority 14 to app-pagegroups
    -- Added extension '700' priority 15 to app-pagegroups
    -- Added extension '700' priority 16 to app-pagegroups
    -- Added extension '700' priority 17 to app-pagegroups
    -- Added extension '700' priority 18 to app-pagegroups
    -- Added extension 'h' priority 1 to app-pagegroups
    -- Registered extension context 'app-page-stream'; registrar: pbx_config
    -- merging incls/swits/igpats from old(app-page-stream) to new(app-page-stream) context, registrar = pbx_ael
    -- Including context 'app-page-stream-custom' in context 'app-page-stream'
Perhaps another call that doesn't happen immediately after the reload to 700?
Thanks for not giving up on me. ;-)
I started the log, then changed the page group to 701, then waited a min. or so, then called 701.
Color me clueless. For giggles, try this. Go into FreePBX and create a Misc Application pointing to the Page Group like the image below except replacing the group with yours of course.
OMG that actually works, WTF!!!
But now my notifications say Bad Destination....
I couldn't hazard a guess why, but it's working so I wouldn't question it. Again - still colored confused, but glad it finally worked for you. Ignore the bad destination.
