I am setting up an IncrediblePBX system on a RPi and have made reasonable progress on it. I can connect to my SIP Service Provider pjsip trunk and receive calls on one of my DIDs that is set up for the pjsip.
The audio is good for incoming calls. The problem is that there is no audio in either direction for outgoing calls even though they ring through and connect. If I change the pjsip authentication settings from OUTGOING to BOTH I have audio on outgoing calls but incoming calls do not connect.
I have focused on the pjsip settings since that is the only "knob" that seems to make a difference but it may be another problem entirely.
TIA! - Jim
TIA! - Jim
