GO HERE Feature Request
It shouldn't be too hard to add. The command freeswitch -version displays it so it should be easy to capture and display
in the PBXStatus screen.
I asked Gemini AI to help with adding the version number and it was a miserable failure. I am currently working with Grok to properly modify the script. Try out the attached file and see if it suits you.
Save it, make it executable and try it before replacing the pbxstatus script in the /ursr/local/sbin/ directory. I would like @wardmundy to try it and bless it if it suits his needs.
Asked gemini to do the same, was ok until it asked to format the display
The resulting modification won't even load now.
I wanted it to display FreeSwitch/ver
Just uploaded. Doesn't display the lan ip or freeswitch version number
Misread what you were looking for. Download from same link again. Not sure what your LAN IP problem is. It works fine for me. Should display LAN IP as well as OpenVPN IP and Tailscale IP if you're using either or both of those.
Latest Posts
mstenner
