AndrewStock
- May 8, 2023
- 23
- 4
Hello All,
IncrediblePBX2027 U when running the module admin module, after installing modules I receive an error message that tells me to run fwconsole ma -verbose. When I run this command in the terminal window, I get this message:
root@noreply:~ $ fwconsole reload
Reload Started
ArgumentCountError: Too few arguments to function freepbx_log(), 1 passed in /var/www/html/admin/modules/codex/Codex.class.php on line 7 and exactly 2 expected in file /var/www/html/admin/libraries/utility.functions.php on line 74
Stack trace:
1. ArgumentCountError->() /var/www/html/admin/libraries/utility.functions.php:74
2. freepbx_log() /var/www/html/admin/modules/codex/Codex.class.php:7
3. FreePBX\modules\Codex->postReloadFreepbx() /var/www/html/admin/libraries/BMO/Hooks.class.php:212
4. call_user_func_array() /var/www/html/admin/libraries/BMO/Hooks.class.php:212
5. FreePBX\Hooks->processHooksByClassMethod() /var/www/html/admin/libraries/Console/Reload.class.php:486
6. FreePBX\Console\Command\Reload->reload() /var/www/html/admin/libraries/Console/Reload.class.php:91
7. FreePBX\Console\Command\Reload->execute() /var/www/html/admin/libraries/Composer/vendor/symfony/console/Command/Command.php:255
8. Symfony\Component\Console\Command\Command->run() /var/www/html/admin/libraries/Composer/vendor/symfony/console/Application.php:992
9. Symfony\Component\Console\Application->doRunCommand() /var/www/html/admin/libraries/Composer/vendor/symfony/console/Application.php:255
10. Symfony\Component\Console\Application->doRun() /var/www/html/admin/libraries/Composer/vendor/symfony/console/Application.php:148
11. Symfony\Component\Console\Application->run() /var/lib/asterisk/bin/fwconsole:163
How do I clear these issues so that my PBX will reload after I have made changes?
Any and all help is greatfully appreciated.
Reload Started
Stack trace:
