wardmundy
Nerd Uno
- Oct 12, 2007
- 20,230
- 5,983
If you need to connect to a Ma Bell line, the OBi110 is the way to go.
[GalaxyS4]
address=10:D5:42:16:15:CF ; the address of the phone
port=3 ; the rfcomm port number (from mobile search in step #3)
context=from-trunk ; dialplan context for incoming calls
adapter=blue ; adapter to use
group=1 ; this phone is in channel group 1
sms=yes ; support SMS, defaults to yes but had to force it for S4
nocallsetup=yes ; set this only if your phone reports that it supports call progress notification, but does not do it. Motorola L6 for example.
/usr/local/bin/brcm43xx-firmware-update
/usr/sbin/hciattach -n /dev/brcm43xx any 3000000 &
amportal restart
/etc/init.d/bluetooth restart
amportal restart
p
d
2
n
p
2
p
w
e2fsck -fy /dev/sda2
resize2fs /dev/sda2
mount /dev/mmcblk0p1 /boot
sed -i 's|mmcblk0p2|sda2|' /boot/uEnv.txt
echo "/dev/sda2 / ext4 relatime,errors=remount-ro 0 1" >> /etc/fstab
echo "/dev/sda1 / ext4 relatime,errors=remount-ro 0 1" >> /etc/fstab
mkdir /esata1
mount /dev/sda1 /esata1
mkdir /esata2
mount /dev/sda2 /esata2
sed -i 's|mmcblk0p2|sda2|' /esata1/boot/uEnv.txt
sed -i 's|mmcblk0p1|sda2|' /esata2/etc/fstab
sed -i 's|mmcblk0p0|sda1|' /esata2/etc/fstab
unless somebody is so strapped for money that cellular service with an existing unlimited calling plan is the only available option to make and receive calls.
one can stand. In this case, we're over our threshold. A buck solves the connection and audio problems. But the solution is nowhere close to meeting the WAF standard for real phone calls. So... BT case closed (at least for us).
apt-get -y install samba samba-common python-glade2 system-config-samba
cd /etc/samba
mv smb.conf smb.orig.conf
wget http://incrediblepbx.com/samba-ubuntu.tar.gz
tar zxvf samba-ubuntu.tar.gz
rm *.tar.gz
sed -i '/# End of Trusted Provider Section/r '/etc/samba/smb.iptables'' /etc/iptables/rules.v4
iptables-restart
service smbd restart
service nmbd restart
sed -i 's|/usr/local/sbin/amportal restart|service smbd restart\nservice nmbd restart\n/usr/local/sbin/amportal restart|' /etc/rc.local
# set up root password for SAMBA access with full RW privileges
smbpasswd -a root
useradd joeschmo --shell /bin/false
smbpasswd -a joeschmo
sed -i 's|root|root joeschmo|' /etc/samba/smb.conf
Live Chat
Video Conferencing
Check your inbox!
