Joe Diamond CPA
- May 5, 2022
- 244
- 78
Hi everyone, successfully installed the TCREEK (git hub) queue callback v17! download the ZIP folder, go to module upload in IPBX and install! the module will appear, Ill let you know how it goes.
if you get an retrieve_conf failed to sym link: /var/lib/asterisk/sounds/en/custom from qcallback/sounds (Already exists, not a link) Do this........................mv /var/lib/asterisk/sounds/en/custom /var/lib/asterisk/sounds/en/custom.bak...............................then................ fwconsole reload...............then..............ls -l /var/lib/asterisk/sounds/en/, the warninng on the dashboard should go away.
