FYI IPBX 2026 for Debian 13 on my favorite Cloud Provider
redstonemason
Certified AWS Architect (And a KVM fan!!!)
Up and running PBX 2026 on Debian 13.7 on Racknerd !!!
1) Build took about 30 minutes on a 2 CPU/2.5 GB instance.
2) I cut and paste my setup from the existing system. Took a while and I made typo's.
3) Noticed that IPTables is still the production system and all the rules seem to propagate into NFTables nicely.
3b) I only use one NFT command: 'nft list ruleset'. But i like it for the packet and byte counts that are displayed.
4) Postfix is working but I use AWS SES to relay so delivery of voicemail messages is usually 100%.
5) I don't use Tailscale, Openvpn but rather run a ssh reverse tunnel to my office for safe GUI access.
6) This is a small system because I am now semi-retired but memory footprint is less than 600M on startup.
6b) Other systems in production are being closed down soon.
7) I don't understand if the "-p" parameter does anything useful when calling "pbxstatus -p".
7b) The Postfix status in the aforementioned comment is wrong because the the script looks for 'sendmail'.
8) The /root/sigfix command was recommended by Ward and it gets rid of the GUI warning about modules.
8b) Not sure why 'sigfix' should be run twice.
9) I changed "/usr/local/sbin/sendmailmp3" to not do any IBM transcript stuff.
10) I would happy to share some of my config files with some redacted stuff if anyone has questions.
I have likely missed a few other changes but I will add them here with a line starting with EDIT.
EDIT
Mark in Toronto, Canada
SuperBricks
