R.I.P. IPBX 2027-D install problem
rockeater
I am trying to install a fresh copy of 2027-D on racknerd. There a a lot of debian org not found messages and it ends up stopping when trying to run mysql later. Is this a temporary debian problem or a bug that needs fixing?
I would strongly recommend you switch to Incredible PBX 2026. 2027-D with Debian 11 has reach EOL at the end of August, 2026.
@rockeater: Bottom line is you're going to have a nightmare of a time trying to cleanly install Debian 11 now. My recommendation would be to switch to Incredible PBX 2026-D. But, if you want to stick with Incredible PBX 2027, then switch to 2027-U with Ubuntu 22.04 which still works fine, or move to one of the virtual machine platforms which already has a 2027-D image built. This is typical Debian conduct, by the way. I had just forgotten that the deadline on the release had passed. :puke:
Thanks for your quick answer. My racknerd only has 1 gig so I installed 2027-U. I tried 2026 on Debian 13, and it seemed to work, but went back to 2027. It did take about 3 Ubuntu installs to get an error free installation.
Bxd4eva
