R.I.P. iPBX 2021 debian - how to add res_config_mysql.so module
pbxfreeck
The PBX2021 does not have the res_config_mysql.so module, which I need to run the additional application. Also, it is not in the addons sourcs folder. How do I add it to a PBX?
Thank's! I have already solved the problem myself, in the way you suggest.
I need to add res_config_mysql.so to asterisk/modules for my application on incrediblePbx 2021.
Could you share the way you succeeded to do that ?
@Soriya: I think iPBX2021 used res_config_sqlite3.so instead of mysql. You need to upgrade to Incredible PBX 2027. Debian Buster security updates were discontinued in June, 2022.
Just the FYI, both res_config_sqlite3 and res_config_mysql are for the RealTime functionality of Asterisk, those manage the backend for the database used for RealTime configuration. FreePBX/IPBX do not use RealTime by default.
What application are you installing that requires the RealTime database?
A2billing. Right now I fo not use realtime
IPBX 2021 currently supports 3 engines : odbc, curl and pgsql
Have you been running A2Billing already? If so, what version of Asterisk?
RandomPerson
