Solved: Hamachi Install including 64-bit trick
TheShniz
"Best example:
Anyone remember when A2Billing first garnered popularity and the install scripts that floated about? Everytime A2Billing released an update, those previous scripts were simply edited... that's not possible here, not even within PiaF.
Would you like to type less /usr/local/sbin/install-a2billing at the command line, then offer your humble and abject apologies for the statement above which is just plain wrong.
I've installed piaf 1.2 and yet get this message
install-hamachi Version 1.0.0 released on Date 053108
Running on 32 Bit CentOS
*This script will only run on PBX in a Flash! You appear not *
*to be running a valid PBX in a Flash system. Attempts to run *
*this program on a non PBX in a Flash install contravenes the *
*terms of use *
And I can't install hamachi. Why?:confused5:
what version of PIAF? 1.2? or 1.1?
what version of asterisk 1.4 or 1.6
what version of O/S 32 bit or 64 bit
I just retested it on PIAF 1.2 in the usual 4x4 matrix Ast 14/16 and 32/64bit no problems except on 64 bit needing an additional library. I get no error message such as you are experiencing. I used the downloaded version just to be sure there were no differences between the development and the release versions.
