SOLVED User Control Panel FAILS
With the exception of commercial modules, Clearly IP uses modules from Sangoma mirrors.
Unless things have changed, modules in the git repos do not include module signatures so they are different files.
I just updated to 16.0.37, and it fails for me with no error message. You simply can't log in. 16.0.36 works fine.
Hi all,
after the Downgrade to 16.0.36 it works fine for me :)
Thank you all for the help
Daniel
There was an update to client javascript code between 16.0.36 and 16.0.37. Maybe you would just need to clear browser cache after updating.
Logging out and back into FreePBX solved the failure without an error message issue, but that was different than the error posted originally which we also experienced.
My install is new (today) and I had trouble logging in on 16.0.38 but downgraded to 16.0.36 and it works like a charm.
