GOOD NEWS Incredible PBX for Elastix 2.5
GREAT writeup on Nerd Vittles; This COULD WELL prove to be the best release ever!!!!
No go for me on the first try, I am installing on a bare metal box, Atom with 1gb ram.
All was going fine but on the 2nd pass of ./IncrediblePBX11-Elastix25.sh it froze. this is the last info on screen
2015-03-10 19:03:33 (231 KB/s) - `iptables-incrediblepbx.tar.gz' saved [13445/13445]
usr/local/sbin/iptables-restart
etc/sysconfig/rules.v4.incredible
etc/sysconfig/rules.v6.incredible
root/add-fqdn
root/add-ip
root/del-acct
root/COPYING
mv: cannot stat `iptables': No such file or directory
mv: cannot stat `ip6tables': No such file or directory
Stopping fail2ban: ERROR Unable to contact server. Is it running?
[FAILED]
Starting fail2ban: [ OK ]
Applying ip6tables firewall rules: ip6tables-restore v1.3.5: ip6tables-restore: unable to initializetable 'filter'
Error occurred at line: 3
Try `ip6tables-restore -h' or 'ip6tables-restore --help' for more information.
[FAILED]
Flushing firewall rules: [ OK ]
Setting chains to policy ACCEPT: filter [ OK ]
Unloading iptables modules:
gary.
Sounds like the firewall blocked you. Download the installer again. I've moved the IPtables section to the end of the install now. I'd comment out the IPtables section before trying a fresh install. Then cut-and-paste the IPtables section into a separate script and run it after the install completes. Let us know where the problem lies. Are you in an IPv6 environment?? Did you disable IPv6 in the Elastix 2.5 setup process?
Yes I did disable IPv6.
I removed the IPtables section from the script and ran twice then ran the IPtables section once and it installed fine, Status shows IPtables & fail2ban is now up.
Thanks.
When I login I see this.
Retrieving... tar: lastupdate-elastix025.tar.gz: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error exit delayed from previous errors
/root/update-my-pbx: line 23: /root/lastupdate-elastix025: No such file or directory
Then status shows all is UP.
gary
gary
Yep. Hadn't quite finished the Automatic Update Utility. It's working now.
what is going on with sip guests on an elastix 2.5 default install, scary stuff in the asterisk log
Not seeing that here. Is the firewall working?? Or is this before Incredible PBX install?
before incrediblepbx install, fpbx 2.11 sip guests does not work, and there is something in custom conf.
the incredible pbx does not check for 64 bit install on first run, is this intentional?
Not sure if this should go here, or in the bugs/fixes section. Installed this today on a rentpbx server, and couldn't get any trunks to register. Ended up being SIP wasn't loaded at all, and the log was filled with nice things like:
[2015-05-04 14:11:11] WARNING[9082] loader.c: Unable to open modules directory '/usr/lib64/asterisk/modules'.
[2015-05-04 14:11:11] NOTICE[9082] loader.c: 4 modules will be loaded.
[2015-05-04 14:11:11] WARNING[9082] loader.c: Error loading module 'format_wav.so':  /usr/lib64/asterisk/modules/format_wav.so: cannot open shared object file: No such file or directory
[2015-05-04 14:11:11] WARNING[9082] loader.c: Error loading module 'format_pcm.so': /usr/lib64/asterisk/modules/format_pcm.so: cannot open shared object file: No such file or directory
[2015-05-04 14:11:11] WARNING[9082] loader.c: Error loading module 'format_mp3.so': /usr/lib64/asterisk/modules/format_mp3.so: cannot open shared object file: No such file or directory
[2015-05-04 14:11:11] WARNING[9082] loader.c: Error loading module 'res_musiconhold.so': /usr/lib64/asterisk/modules/res_musiconhold.so: cannot open shared object file: No such file or directory
[2015-05-04 14:11:11] WARNING[9082] loader.c: Module 'format_wav.so' could not be loaded.
[2015-05-04 14:11:11] WARNING[9082] loader.c: Module 'format_pcm.so' could not be loaded.
[2015-05-04 14:11:11] WARNING[9082] loader.c: Module 'format_mp3.so' could not be loaded.
[2015-05-04 14:11:11] WARNING[9082] loader.c: Module 'res_musiconhold.so' could not be loaded.
Simple fix was to just change a line in asterisk.conf:
astmoddir => /usr/lib64/asterisk/modules
to
astmoddir => /usr/lib/asterisk/modules
Any everything seems to work fine now.
