BUG PIAF3 Install error
himala76
Hello Guys im trying to install PIFA3 after running the scrip server reboot log in select A.
then i get this error.
/usr/local/sbin/newmenu: line 14: /usr/local/sbin/isomenu: cannot execute binary file
can anyone help me on
Himala
login as: root
CentOS release 6.4 (Custom) on \m
In order to continue your
PIAF/SIAF/CIAF/XIAF/FIAF/VIAF Installation
Please log in as root to continue
Your IP Address is:
192.168.2.211
[email protected]'s password:
Last login: Fri Apr  3 15:03:51 2015
*            PIAF group of programs Install Options                    *
* Please choose one of the options listed below. Choosing A will start *
* the regular installation choice menu. Choosing B will allow you to  *
* install drivers that you may need to support your hardware. Choosing *
* C will allow you to go to the Command Line Interface (CLI)          *
* (Most users tap the A key!)                                          *
Your IP Address is:
192.168.2.211
* Please make a selection A, B or C only!            *
* A = Continue with the installation of our products  *
* B = Load extra drivers for your hardware            *
* C = Command Line Interface                          *
You have chosen to install one of our products
root@pbx:~ $
just run piafdl to install PBX in a Flash and ignore this error. We are phasing out isomenu as we no longer produce an ISO! Still working on removing it from the rpm
Also have a look in /usr/local/sbin and see if indeed isomenu is present
Thanks Tom
Himala
