FYI Where are the updates
prattmd2
When I was using FreePBX GUI I was getting updates to modules almost daily
I have yet to see any module updates since installing IncrediblePBX and gui on CentOS about 3 weeks ago
Is that correct or normal?
Modules will be screened carefully before being released. Perfectly normal AND safer.
Take a look at "the other forum" if you want to see why it makes sense to take your time installing updates.
* EDIT * This is a phone system, not a race car. Absent security issues, the less tinkering you do with it, the better off you will be.
prattmd2: Assuming you're not using your system for production, you can assist us with testing the newer modules for Module Admin by changing the module update location on your server and restarting Asterisk. We haven't found any issues with the new updates thus far. The command is below.
Remember that, after updating/adding modules, you'll need to manually clear the nasty warning messages in the GUI's System Status screen. Then permanently delete them by running gui-fix from the Linux CLI. Our overlords calls this a feature. :rolleyes:
It will be removed in an upcoming release from us.
mysql -u root -ppassw0rd asterisk -e "update freepbx_settings set value='http://wable-repo2.wardmundy.net' where keyword='MODULE_REPO' and description='repo server' limit 1"
amportal restart
I ran this on a test box (
Incredible PBX 12.0.70)
and everything seemed to work, it update about 6 modules, warnings came up but were deleted successfully.
Thanks,
gary
Ward: I noticed in your article today that Incredible GUI had been upgraded to include Google Voice OAUTH configurations.
How do you update Incredible GUI itself?
I yearn to live as close to the edge as humanly possible as long as it's only in the world of software, ip addresses, FQDN's, firewalls and VM's
Get too close to that edge and you might fall off. "There be Monstyrs!" :)
