TIPS Extra Steps: Certified Incredible Builds
jeff.h
Incredible PBX 13-12.2-CentOS-6.7 (32-bit and 64-bit)
Tutorial: http://nerdvittles.com/?p=14208
Install Steps: Follow tutorial; activate swapfile on Digital Ocean;yum -y install net-tools nano wget && yum -y update && reboot; run Incredible PBX and Incredible Fax installers
Results: Incredible PBX and Incredible Fax install correctly
09-22-2015 Update: Latest installer adds support for 32-bit CentOS/Scientific Linux 6.7 platforms. New SL67-32-minimal.ISO on SourceForge.
Notes: Mail successfully sent. Check SPAM folder and whitelist address if necessary. Successfully logged into AvantFax using web credentials. All IAX modems on line. Successfully logged into Incredible GUI after setting admin password with admin-pw-change. No issues reported. Asterisk still appears to be running as root.
Fixes: Version incorrectly displays as 13-12.0 even though it's the 13-12.2 installer: echo 13-12.2 > /etc/pbx/.version. Fixed in 09-08-2015 installer. Running as root issue fixed in 09-09-2015 installer. For existing systems, follow this link and this link for both of the required fixes.
Hey Ward, the tutorial says to perform some additional steps for 6.5/6.6 systems, do we still need to perform those same things for 6.7?
jeff.h On a true CentOS 6.7 platform, at a minimum, always run these before beginning an install:
yum -y upgrade
reboot
yum -y upgrade
reboot
Ok yeah, I always run those, but I wasn't sure about these....
# for CentOS/Scientific Linux 6.5/6.6 platforms, perform these additional steps: wget http://incrediblepbx.com/update-kernel-devel chmod +x update-kernel-devel ./update-kernel-devel
