SOLVED Incredible 13 bails ugly on calls between internal ext.
Kimmy Dallas Posey
Ok. I have two endpoints, a Grandstream BT-100 on my desk and a HandyTone-286 in my barn. Both have been rock solid phones for years. I pointed them away from my old PIAF box and to my new Incredible 13 iso box. They both register and I can make outbound calls. But when I try to dial between then I get crickets. And if I hit the "send" on the BT-100, it looses registration AND asterisk get's very unhappy and restarts. I see these in the log which look ominous but have no idea what they mean:
[2015-10-17 09:37:52] ERROR[4877] res_pjsip.c: Unable to create outbound OPTIONS request to endpoint <none>
[2015-10-17 09:37:52] ERROR[4877] res_pjsip/pjsip_options.c: Unable to create request to qualify contact sip:[email protected]:5060
[2015-10-17 09:38:18] ERROR[4877] res_pjsip.c: Unable to create outbound OPTIONS request to endpoint <none>
[2015-10-17 09:38:18] ERROR[4877] res_pjsip/pjsip_options.c: Unable to create request to qualify contact sip:[email protected]:5060
[2015-10-17 09:38:46] ERROR[4877] res_pjsip.c: Unable to create outbound OPTIONS request to endpoint <none>
[2015-10-17 09:38:46] ERROR[4877] res_pjsip/pjsip_options.c: Unable to create request to qualify contact sip:[email protected]:5060
[2015-10-17 09:38:52] ERROR[4877] res_pjsip.c: Unable to create outbound OPTIONS request to endpoint <none>
[2015-10-17 09:38:52] ERROR[4877] res_pjsip/pjsip_options.c: Unable to create request to qualify contact sip:[email protected]:5060
[2015-10-17 09:39:18] ERROR[4877] res_pjsip.c: Unable to create outbound OPTIONS request to endpoint <none>
[2015-10-17 09:39:18] ERROR[4877] res_pjsip/pjsip_options.c: Unable to create request to qualify contact sip:[email protected]:5060
What really confuses me is that when the extensions are configured for chan-sip I get the SAME logs. Why would res_pjsip.c log about an extension that isn't configured to use pjsip? Seems weird.
There are lots of other logs of course. Any help would be appreciated.
Are you on port 5061 with your SIP connections?? That's the port for traditional SIP communications under FreePBX.
Humm ... I left everything default excepting user/password as far as I remember. I originally configured the extensions for chan-sip and couldn't get them to register and I was seeing the above mentioned logs. Again that was with chan-sip configured. Then I too a look at how ext 701 was configured, deleted the extensions I had created and started over, using pjsip because that is how 701 came out of the box. The phones registered then and I could make external calls. But when I tried to dial the barn extension I got silence. So I went # asterisk -rvvvvvvvvv to what the call progress and as soon as I dialed 704 (the ht-286 in the barn) from 705 (bt-100 in my office) I immediately got dumped back to the bash shell. That is really what made me post because that almost can't be a cockpit error. Anyway here is how the ports are configured on both the server and the clients:
PBX extension config for both has this note:
"This device uses PJSIP technology listening on udp:0.0.0.0:5060"
HT-286 says:
local SIP port: (default 5060)
local RTP port: (1024-65535, default 5004)
BT-100 says:
We eat our own dog food. I use Incredible PBX 13 all day every day between local extensions. Just tried the latest release using this week's Nerd Vittles Intel NUC setup. Created 701 and 702 PJSIP extensions. Used Telephone app on the Mac to create two softphones for the extensions. Can call between them without any problems. That tells me it's either your phones that are misconfigured, or something is damaged on your server. The quick test is to set up two extensions and use softphones to call between them. That will tell you whether it's a phone or server problem.
    -- Executing [s@macro-dial-one:44] Dial("PJSIP/702-0000002e", "PJSIP/701/sip:[email protected]:53125;ob,15,TtrI") in new stack
    -- Called PJSIP/701/sip:[email protected]:53125;ob
    -- PJSIP/701-0000002f is ringing
    -- PJSIP/701-0000002f answered PJSIP/702-0000002e
    -- Channel PJSIP/701-0000002f joined 'simple_bridge' basic-bridge <aca50482-34fe-45fe-9b68-729507e2e3df>
    -- Channel PJSIP/702-0000002e joined 'simple_bridge' basic-bridge <aca50482-34fe-45fe-9b68-729507e2e3df>
      > 0xb34e0568 -- Probation passed - setting RTP source address to 192.168.0.177:4098
      > 0xb34e4388 -- Probation passed - setting RTP source address to 192.168.0.177:4096
    -- Channel PJSIP/701-0000002f left 'simple_bridge' basic-bridge <aca50482-34fe-45fe-9b68-729507e2e3df>
    -- Channel PJSIP/702-0000002e left 'simple_bridge' basic-bridge <aca50482-34fe-45fe-9b68-729507e2e3df>
I have same problem Asterisk 13.6.0 Incredible GUI 12.0.30 running on Ubuntu 14.04.03 in VM on ESXi. I messed up my previous setup and whilst I got it back up it wasn't quite right so created new pbx and copied extensions etc over using csv export / import. I have the same errors and likewise can make external calls but if I try internal call asterisk crashes with last message pjsip .... role is unknown agent. I've power cycled phones to no avail. I suspect it may be related to this problem http://community.freepbx.org/t/issu...registration-and-new-extensions-showing/26770. I also wonder if maybe some settings from previous set-up are getting carried accross and the problem may cure itself with time. I'm not sure how to debug further but willing to try if you point me in the right direction.
[2015-10-18 19:40:08] VERBOSE[5260][C-00000000] pbx.c: Executing [s@macro-dial-one:44] Dial("PJSIP/202-00000000", "PJSIP/227/sip:[email protected]:2048;line=fao4tt4x,,TtrI") in new stack
[2015-10-18 19:40:08] DEBUG[1888] cel_odbc.c: Executing SQL statement: [INSERT INTO cel (eventtype,eventtime,cid_name,cid_num,cid_ani,cid_rdnis,cid_dnid,exten,context,channame,appname,appdata,amaflags,accountcode,uniqueid,linkedid,peer,userdeftype,userfield) VALUES ('CHAN_START',{ts '2015-10-18 19:40:08.404704'},'device','227','','','','s','from-internal','PJSIP/227-00000001','','',3,'','1445193608.2','1445193608.0','','','')]
[2015-10-18 19:40:08] DEBUG[1888] res_odbc.c: odbc_release_obj2(0x3b46438) called (obj->txf = (nil))
[2015-10-18 19:40:08] DEBUG[5260][C-00000000] channel.c: Inheriting variable __KEEPCID from PJSIP/202-00000000 to PJSIP/227-00000001.
[2015-10-18 19:40:08] DEBUG[5260][C-00000000] channel.c: Inheriting variable __CWIGNORE from PJSIP/202-00000000 to PJSIP/227-00000001.
[2015-10-18 19:40:08] DEBUG[5260][C-00000000] channel.c: Inheriting variable __REC_POLICY_MODE from PJSIP/202-00000000 to PJSIP/227-00000001.
[2015-10-18 19:40:08] DEBUG[5260][C-00000000] channel.c: Inheriting variable __MON_FMT from PJSIP/202-00000000 to PJSIP/227-00000001.
[2015-10-18 19:40:08] DEBUG[5260][C-00000000] channel.c: Inheriting variable __FROMEXTEN from PJSIP/202-00000000 to PJSIP/227-00000001.
[2015-10-18 19:40:08] DEBUG[5260][C-00000000] channel.c: Inheriting variable __TIMESTR from PJSIP/202-00000000 to PJSIP/227-00000001.
[2015-10-18 19:40:08] DEBUG[5260][C-00000000] channel.c: Inheriting variable __YEAR from PJSIP/202-00000000 to PJSIP/227-00000001.
[2015-10-18 19:40:08] DEBUG[5260][C-00000000] channel.c: Inheriting variable __MONTH from PJSIP/202-00000000 to PJSIP/227-00000001.
[2015-10-18 19:40:08] DEBUG[5260][C-00000000] channel.c: Inheriting variable __DAY from PJSIP/202-00000000 to PJSIP/227-00000001.
[2015-10-18 19:40:08] DEBUG[5260][C-00000000] channel.c: Inheriting variable __REC_STATUS from PJSIP/202-00000000 to PJSIP/227-00000001.
[2015-10-18 19:40:08] DEBUG[5260][C-00000000] channel.c: Inheriting variable __PICKUPMARK from PJSIP/202-00000000 to PJSIP/227-00000001.
[2015-10-18 19:40:08] DEBUG[5260][C-00000000] channel.c: Inheriting variable __EXTTOCALL from PJSIP/202-00000000 to PJSIP/227-00000001.
[2015-10-18 19:40:08] DEBUG[5260][C-00000000] channel.c: Inheriting variable __TTL from PJSIP/202-00000000 to PJSIP/227-00000001.
[2015-10-18 19:40:08] DEBUG[5260][C-00000000] channel.c: Inheriting variable __DIAL_OPTIONS from PJSIP/202-00000000 to PJSIP/227-00000001.
[2015-10-18 19:40:08] DEBUG[5260][C-00000000] channel.c: Inheriting variable __RINGTIMER from PJSIP/202-00000000 to PJSIP/227-00000001.
[2015-10-18 19:40:08] DEBUG[4678] rtp_engine.c: Using engine 'asterisk' for RTP instance '0x7f4ed0020628'
[2015-10-18 19:40:08] DEBUG[4678] res_rtp_asterisk.c: Allocated port 12442 for RTP instance '0x7f4ed0020628'
[2015-10-18 19:40:08] DEBUG[4678] res_rtp_asterisk.c: Creating ICE session 0.0.0.0:12442 (12442) for RTP instance '0x7f4ed0020628'
[2015-10-18 19:40:08] DEBUG[4678] pjsip: icess0x7f4ed00 ICE session created, comp_cnt=2, role is Unknown agent
May not be relevant but both phones are on local network and have ICE support set to no in GUI
Oh I don't doubt the PBX works wardmundy and I don't mean to imply that. After all I've been using the project since almost the beginning. I've deployed it in multiple businesses I've owned, with multiple sites trunked together, remote extensions, you name it. I know you guys put out a good well tested load and you run it in house. The point is I've configured many, many extensions. And even if I was a total looper, I should not be able to screw it up so bad that dialing from one registered endpoint to another causes a restart:
Two softphones, ext 701, a Yateclient running in a ubuntu 14.04.3 vm and 702, a ZOIPER instance running natively under kubuntu 14.04.3. Both verified to be configured identically via the GUI except that I didn't enable Voicemail on 702. 701 was preconfigured with Voicemail. One other difference of course is that 701 serves as a destination for one of the IVR Demo options. Other than that and the credentials they're identical. Call starts fine, yakks awhile ...
[snip]
[2015-10-18 21:20:14] WARNING[11409][C-00000000] func_presencestate.c: PRESENCE_STATE unknown
[2015-10-18 21:20:14] VERBOSE[11409][C-00000000] pbx.c: Executing [s@sub-presencestate-display:1] Goto("PJSIP/702-00000000", "state-,1") in new stack
[2015-10-18 21:20:14] VERBOSE[11409][C-00000000] pbx.c: Goto (sub-presencestate-display,state-,1)
[2015-10-18 21:20:14] VERBOSE[11409][C-00000000] pbx.c: Executing [state-@sub-presencestate-display:1] Set("PJSIP/702-00000000", "PRESENCESTATE_DISPLAY=") in new stack
[2015-10-18 21:20:14] VERBOSE[11409][C-00000000] pbx.c: Executing [state-@sub-presencestate-display:2] Return("PJSIP/702-00000000", "") in new stack
[2015-10-18 21:20:14] VERBOSE[11409][C-00000000] pbx.c: Executing [s@macro-dial-one:40] Set("PJSIP/702-00000000", "CONNECTEDLINE(name,i)=701") in new stack
[2015-10-18 21:20:14] VERBOSE[11409][C-00000000] pbx.c: Executing [s@macro-dial-one:41] Set("PJSIP/702-00000000", "CONNECTEDLINE(num)=701") in new stack
[2015-10-18 21:20:14] VERBOSE[11409][C-00000000] pbx.c: Executing [s@macro-dial-one:42] Set("PJSIP/702-00000000", "D_OPTIONS=TtrI") in new stack
[2015-10-18 21:20:14] VERBOSE[11409][C-00000000] pbx.c: Executing [s@macro-dial-one:43] Macro("PJSIP/702-00000000", "dialout-one-predial-hook,") in new stack
[2015-10-18 21:20:14] VERBOSE[11409][C-00000000] pbx.c: Executing [s@macro-dialout-one-predial-hook:1] MacroExit("PJSIP/702-00000000", "") in new stack
[2015-10-18 21:20:14] VERBOSE[11409][C-00000000] pbx.c: Executing [s@macro-dial-one:44] Dial("PJSIP/702-00000000", "PJSIP/701/sip:[email protected]:5060,15,TtrI") in new stack
Then boom. Looks like a restart of some kind to me. I'm pretty certain that isn't supposed to happen no matter what I configure or what I dial
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
[2015-10-18 21:20:19] Asterisk 13.6.0 built by root @ IncrediblePBX.local on a i686 running Linux on 2015-10-10 01:38:43 UTC
[Oct 18 21:20:19] VERBOSE[11418] config.c: Parsing '/etc/asterisk/logger.conf': Found
[Oct 18 21:20:19] VERBOSE[11418] config.c: Parsing '/etc/asterisk/logger_general_additional.conf': Found
[Oct 18 21:20:19] VERBOSE[11418] config.c: Parsing '/etc/asterisk/logger_general_custom.conf': Found
[Oct 18 21:20:19] VERBOSE[11418] config.c: Parsing '/etc/asterisk/logger_logfiles_additional.conf': Found
[Oct 18 21:20:19] VERBOSE[11418] config.c: Parsing '/etc/asterisk/logger_logfiles_custom.conf': Found
[snip]
Maybe my hardware is just old (which it is) but I don't think that's the issue. The install must have failed somehow right?
An update on this one. I have a mix of pjsip and chan_sip extensions (I need distinctive ringing on some phones and pjsip won't pass ALERT INFO in FreePBX12 although it is supposed to be coming in v13). Any call which terminates in a chan_sip extension works fine regardless of source type and any call where the destination is a pjsip extension causes Asterisk to crash (again source agnostic). To rule out hardware I've created 2 new YATE clients using the default pjsip settings and get exactly the same behaviour as with hard phones. Notably if I turn off the computer running the destination YATE client but call it's extension Asterisk still crashes. Code below stops dead after last line. I was not aware of this problem on the system I waqs setting up which I messed up and the only significant difference I can see between the two is that the previous version was running Asterisk 13.5 and the problem system is running 13.6
[2015-10-19 19:03:11] VERBOSE[5454][C-00000000] pbx.c: Executing [s@macro-dial-one:44] Dial("PJSIP/281-00000000", "PJSIP/282/sip:[email protected]:55868,,TtrI") in new stack
[2015-10-19 19:03:11] DEBUG[1898] cel_odbc.c: Executing SQL statement: [INSERT INTO cel (eventtype,eventtime,cid_name,cid_num,cid_ani,cid_rdnis,cid_dnid,exten,context,channame,appname,appdata,amaflags,accountcode,uniqueid,linkedid,peer,userdeftype,userfield) VALUES ('CHAN_START',{ts '2015-10-19 19:03:11.994343'},'device','282','','','','s','from-internal','PJSIP/282-00000001','','',3,'','1445277791.2','1445277791.0','','','')]
[2015-10-19 19:03:11] DEBUG[1898] res_odbc.c: odbc_release_obj2(0x279e008) called (obj->txf = (nil))
[2015-10-19 19:03:11] DEBUG[5454][C-00000000] channel.c: Inheriting variable __KEEPCID from PJSIP/281-00000000 to PJSIP/282-00000001.
[2015-10-19 19:03:11] DEBUG[5454][C-00000000] channel.c: Inheriting variable __CWIGNORE from PJSIP/281-00000000 to PJSIP/282-00000001.
[2015-10-19 19:03:11] DEBUG[5454][C-00000000] channel.c: Inheriting variable __MON_FMT from PJSIP/281-00000000 to PJSIP/282-00000001.
[2015-10-19 19:03:11] DEBUG[5454][C-00000000] channel.c: Inheriting variable __FROMEXTEN from PJSIP/281-00000000 to PJSIP/282-00000001.
[2015-10-19 19:03:11] DEBUG[5454][C-00000000] channel.c: Inheriting variable __TIMESTR from PJSIP/281-00000000 to PJSIP/282-00000001.
[2015-10-19 19:03:11] DEBUG[5454][C-00000000] channel.c: Inheriting variable __YEAR from PJSIP/281-00000000 to PJSIP/282-00000001.
[2015-10-19 19:03:11] DEBUG[5454][C-00000000] channel.c: Inheriting variable __MONTH from PJSIP/281-00000000 to PJSIP/282-00000001.
[2015-10-19 19:03:11] DEBUG[5454][C-00000000] channel.c: Inheriting variable __DAY from PJSIP/281-00000000 to PJSIP/282-00000001.
[2015-10-19 19:03:11] DEBUG[5454][C-00000000] channel.c: Inheriting variable __REC_STATUS from PJSIP/281-00000000 to PJSIP/282-00000001.
[2015-10-19 19:03:11] DEBUG[5454][C-00000000] channel.c: Inheriting variable __PICKUPMARK from PJSIP/281-00000000 to PJSIP/282-00000001.
[2015-10-19 19:03:11] DEBUG[5454][C-00000000] channel.c: Inheriting variable __EXTTOCALL from PJSIP/281-00000000 to PJSIP/282-00000001.
[2015-10-19 19:03:11] DEBUG[5454][C-00000000] channel.c: Inheriting variable __TTL from PJSIP/281-00000000 to PJSIP/282-00000001.
[2015-10-19 19:03:11] DEBUG[5454][C-00000000] channel.c: Inheriting variable __DIAL_OPTIONS from PJSIP/281-00000000 to PJSIP/282-00000001.
[2015-10-19 19:03:11] DEBUG[5454][C-00000000] channel.c: Inheriting variable __RINGTIMER from PJSIP/281-00000000 to PJSIP/282-00000001.
[2015-10-19 19:03:11] DEBUG[4111] rtp_engine.c: Using engine 'asterisk' for RTP instance '0x7fb244020e48'
[2015-10-19 19:03:11] DEBUG[4111] res_rtp_asterisk.c: Allocated port 13424 for RTP instance '0x7fb244020e48'
[2015-10-19 19:03:11] DEBUG[4111] res_rtp_asterisk.c: Creating ICE session 0.0.0.0:13424 (13424) for RTP instance '0x7fb244020e48'
[2015-10-19 19:03:11] DEBUG[4111] pjsip: icess0x7fb2440 ICE session created, comp_cnt=2, role is Unknown agent
[2015-10-19 19:03:11] DEBUG[4111] pjsip: icess0x7fb2440 Candidate 0 added: comp_id=1, type=host, foundation=Hc0a80502, addr=192.168.5.2:13424, base=192.168.5.2:13424, prio=0x7effffff (2130706431)
[2015-10-19 19:03:11] DEBUG[4111] rtp_engine.c: RTP instance '0x7fb244020e48' is setup and ready to go
[2015-10-19 19:03:11] DEBUG[4111] res_rtp_asterisk.c: Setup RTCP on RTP instance '0x7fb244020e48'
[2015-10-19 19:03:11] DEBUG[4111] pjsip: icess0x7fb2440 Candidate 1 added: comp_id=2, type=host, foundation=Hc0a80502, addr=192.168.5.2:13425, base=192.168.5.2:13425, prio=0x7efffffe (2130706430)
[2015-10-19 19:03:11] DEBUG[4111] pjsip: icess0x7fb2440 Destroying ICE session 0x7fb244063b38
[2015-10-19 19:03:11] DEBUG[4111] pjsip: ice_session.c ICE session 0x7fb244063b38 destroyed
Hi,
I got exactly the same error as kimmy dallas.
I have a test vps i use and been working flawlessly for 3 months.
I thought i would also try and restall same error. It happens on both VPS server.
Could it perhaps be something new in scripts?
Out going calls a perfect its just internal extension to extension
[2015-10-21 09:22:54] ERROR[4652] res_pjsip.c: Unable to create outbound OPTIONS request to endpoint <none>
[2015-10-21 09:22:54] ERROR[4652] res_pjsip/pjsip_options.c: Unable to create request to qualify contact sip:916@PUBLIC IP:5060
[2015-10-21 09:23:04] ERROR[4652] res_pjsip.c: Unable to create outbound OPTIONS request to endpoint <none>
[2015-10-21 09:23:04] ERROR[4652] res_pjsip/pjsip_options.c: Unable to create request to qualify contact sip:905@PUBLIC IP:1024
Please document the status info for the version that worked and the one that doesn't. Thanks.
Hi Thank you for the reply wardmundy :) the orig was the same site i used both using incrediblepbx 13-12.2 I use centos so i tried your new unbuntu 14 one and have exactly the same error. All else works flawlessly just cant ring between extensions with above error in logs. Kind Regards Cam
I've just moved a couple of phones using PJSip across to the old system and can dial between them OK. Both are ESXi VMs running Ubuntu 14.04.3 LTS. The new (problem) one Kernel Version 3.19.0-30-generic (SMP) x86_64 and the old one Kernel Version 3.13.0-65-generic (SMP) x86_64. As previously stated the new one is on Asterisk 13.6.0 and the old one on 13.5.0 so my guess is that is where the problem lies
Try running the upgrade Asterisk script to get up to latest release again and see if it solves it.
Upgrade script run OK but version stays at 13.6.0 Checked CLI to confirm new build time. Initial testing seems to show that the problem has been fixed. Leads me to think that something went awry during the initial compile. Thanks
YAY, wardmundy simply awesome :) Asterisk still says 13.6 and incredible 12.0 but it fixed the internal extensions. I used Incredible PBX 13-12.2-CentOS-6.7 (32-bit and 64-bit) then asterisk upgrade script to fix. Champion Kind Regards Cam
I'm having a similar issue on ubuntu (digital-ocean) when calling into an extension:
[2015-11-02 12:25:36] ERROR[5784] res_pjsip.c: Unable to create outbound OPTIONS request to endpoint <none>
[2015-11-02 12:25:36] ERROR[5784] res_pjsip/pjsip_options.c: Unable to create request to qualify contact sip:705@[IP]:5062
Try this and let us know if it helps:
cd /usr/src/asterisk-13*
make
make install
amportal restart
