NO JOY Installing XiVO at CloudAtCost
hecatae
resident hecatae
and it was going so well, this was from a clean Debian install:
Adjusting hostname to FQDN...
New hostname: c170549391-cloudpro-365931528.incrediblepbx.com
To continue with installation, press ENTER. Or press Ctrl-C to abort.
Configuring XiVO. Please wait...
Login to web interface as root with web password.
Traceback (most recent call last):
  File "./wizard.py", line 47, in <module>
    c.wizard.create(wizard)
  File "/usr/lib/python2.7/dist-packages/xivo_confd_client/commands/wizard.py", line 28, in create
    response = self.session.post(url, body, timeout=timeout)
  File "/usr/lib/python2.7/dist-packages/xivo_confd_client/session.py", line 70, in post
    self.check_response(response, check_response)
  File "/usr/lib/python2.7/dist-packages/xivo_confd_client/session.py", line 47, in check_response
    response.raise_for_status()
  File "/usr/lib/python2.7/dist-packages/requests/models.py", line 825, in raise_for_status
    raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 500 Server Error: Unexpected error: sysconfd error: status 500 - <head>
<title>Error response</title>
</head>
<body>
<h1>Error response</h1>
<p>Error code 500.
<p>Message: <pre>
Waiting for services to start successfully...
        starting xivo-auth ... OK
        starting xivo-dxtora ... OK
        starting xivo-provd ...Job for xivo-provd.service failed. See 'systemctl status xivo-provd.service' and 'journalctl -xn' for details.
 NOK
Opening port 5060.
</pre>
<p>Error code explanation: 500 = Server got itself in trouble.
</body>
Please verify no errors shown above in XiVO configuration step.
Looks like it timed out at the Cloud@Cost end. Shocker. :yikes:
curious, is this because the secure firewall is installed afterwards, and on everything else I install, the firewall is the first thing I do?
May just be the all-too-usual slowness on the C@C platform. We've gotten a couple successful builds, but they're dog slow even after a successful install. D.O. and ImpactVPS on the other hand are ideal platforms. And RentPBX is even better... never have to download anything.
