SOLVED What was your most recent successful install?
Yahdie
I literally have 5 hours max to setup PIAF have made 6 attempts all of which end with Asterisk Unknown/Offline
I need to know what version etc has been successfully installed to hardware in the last 48 hours
I have been trying:
 PIAF Installed Version   = 3.0.6.8 under *HARDWARE*                │
   │  FreePBX Version          = 2.11.0.35                               │
   │  Running Asterisk Version = UNKNOWN                                 │
   │  Asterisk Source Version  = 11.16.0                                 │
   │  Dahdi Source Version     = 2.10.0.1                                │
   │  Libpri Source Version    = 1.4.15                                  │
   │  IP Address               = 192.168.35.129 on eth0                  │
   │  Operating System         = CentOS release 6.8 (Final) ><           │
   │  Kernel Version           = 2.6.32-642.4.2.el6.x86_64 - 64 Bit
PIAF is considered outdated. Please install Incredible PBX from Nerd Vittles
As long as the IP is in the iptables firewall then yes
Vultr
Cloud Instance768 MB Server
That's what dynamic DNS addresses are all about. Register an FQDN, set up a client that resides on your computer or Android phone to keep its IP address current, register the FQDN with add-fqdn and add it to ipchecker. Done. Travel all you want to and always have access to your PBX... safely.
