SOLVED Incredible PBX for CentOS 7 install broke ?
stanjohn
Not quite right
Logs: http://www.n4iqt.com/pbx/putty.log
No Joy with vultr restart or console reboot.
I'm having the same result and after going through your putty console log it matches my install log in showing that asterisk is not found and cannot run. I'm by no means an expert but it looks like asterisk is failing to compile properly on both of our installs. I have tried this with CentOS & using the Scientific ISO with the same result.
Trying it now on ImpactVPS and Vultr. Thanks for heads up.
Asterisk 13.11.0 causes major breakage with a number of components so we've moved the installers back to Asterisk 13.10.0 until we can sort out all of the problems.
Thanks Ward, appreciate you promptly fixing the issue. Have a new install to roll out next week for a customer.
Thanks. Asterisk 13.11.0 broke all sorts of things. Not sure why yet. Install log is in /root if you want to have a look.
I propose modifying the installer script such that, when any major steps encounters errors, it exits.
Major time saver for locating why anything broke.
