QUESTION Simultaneous Ring
jward
I am interested in the NoMoRobo service. It requires a feature called simultaneous ring. I think I can set this up using my DID provider Vitelity. However, maybe it makes more sense to implement the feature in Piaf. How would one set up simultaneous ring? Also, thoughts on alternate ways to setup simultaneous ring or using NoMoRobo are welcome. Thanks.
In PBX in a Flash, got to Admin > Follow me.
To enter an outside number to ring with your phone, put it in the screen the same was you would on your phone, ie: 18882345678 and put a pound sign at the end like: 18882345678#. Set the Ring Strategy to "ringallv2". That should do it.
If you have a ring group set up to route the incoming call to multiple extensions, you make the outside number for NoMoRobo in the ring group using the methodology above.
Thanks for the help. That nearly works. While testing I have been using Google Voice for outbound calls which is currently changing the CID to the GV DID breaking Nomorobo. I have read in other threads some of things you do to block unwanted calls. I'll have to keep reading and implement some of those techniques too.
