atsak
- Sep 7, 2009
- 2,473
- 487
Received this today from Octavius Gould ([email protected]) - Ward?
Hi,
We, at PBX in a Flash, would like to inform you that PBX in a Flash Versions 3 and under are no longer supported since the release of PBX in a Flash 5. Due to this recent development, any version prior to PBX in a Flash 5 is considered to be insecure and possess limited features.
PBX in a Flash 5 has solved multiple issues users have faced in the past while using previous versions of PIAF. With zero admin, the ability to deploy both in the cloud and on premise with multiple integrated features; version 5 provides the end-user a communications experience unlike any other.
What’s more, by upgrading you will not only gain a state of the art phone system for free but also gain a complimentary annual license key worth $350!
Free Support
Require support? Don’t worry we have you covered. When you upgrade to PBX in a Flash 5, users also get free access to forum support and resellers also have free access to the support portal.
How to Get the Supported Version
To receive your free PIAF 5 license key, click on the link below and fill in the form. You will receive an email with your free license key details for 8 Simultaneous Calls (25 extensions) and Unlimited SIP Trunks, worth $350.
Claim your FREE 25 extension license NOW
(Offer Valid until the 2nd of May 2017)
Hi,
Free Support
