I remember (now) in the past when the WAN down DNS bug killed my sip extensions, I could manually disable (comment out registrations) all my sip trunks. Then sip extensions on LAN would work again. That meant a PSTN inbound would still ring on my sip extensions.
That's easy, if I'm in the office at the time.
Still need to unplug my WAN to confirm, but I should be fine with all sip extensions if I have only pjsip trunks. Snom phone was fussy using pjsip so far.
So I finally have my Vitelity Inbound DID and outbound trunks working for pjsip.
Incredible Pbx 13-13, latest release.
Here are the settings.
Pjsip outbound
trunkname: vitel-outbound
callerid <7775551212>
Allow any did
Max channels 4
Dial option T
System
Cont if busy, disable trunk No
Dialplan
Prepend 1777 to NXXXXXX
Prepend 1 to NXXNXXXXXX
1NXXNXXXXXX
911
Pjsipsettings
my vitelity sub account Login user name
my Vitelity password
Auth Outbound
Registration Send
Lang default
Sipserver outbound.vitelity.net
Sip port 5060 (yes it is 5060)
from-pstn
transport 0.0.0.0-udp
advanced
DTMF auto/rfc 4733
Forb retry interval 10
Gen retry interval 60
Expiration 3600
Max retries 10
Qualify frequency 60
Outbound proxy is blank
From domain outbound.vitelity.net
Other advanced text boxes are blank
Buttons all no, none
Codecs
Only ulaw checked
Pjsip for Inbound DID
Remember for Vitelity DIDs to set Routing to the subaccount with the username!
Remember on Pbx to set an Inbound route to an IVR or a destination
trunkname: vitel-inbound
hide callerid No
Allow any did
Max channels 4
Dial option T
System
Dialplan
1NXXNXXXXXX
911
Pjsipsettings
my vitelity subaccount userid login name (same as the DID Route to Account name)
my vitelity subaccount password
Auth Outbound
Registration Send
Lang default
Sipserver inbound25.vitelity.net
from-pstn
advanced
DTMF auto
Expiration 3600
Max retries 10
Outbound proxy inbound25.vitelity.net
From domain inbound25.vitelity.net
Codecs
Only ulaw checked
