GOOD NEWS Incredible Ubuntu 18.04
What are the steps in getting Let's Encrypt to work with this distro? I followed the directions from Let's Encrypt for Ubuntu 17.xx on their website. It fails during the http-01 challenge. I take it is because of iptables and/or fail2ban?
What are the steps in getting Let's Encrypt to work with this distro? I followed the directions from Let's Encrypt for Ubuntu 17.xx on their website. It fails during the http-01 challenge. It take it is because of iptables and/or fail2ban?
I think @wardmundy has an article on it but Im not sure if he has steps for Ubuntu.
Haven't tackled 18.04 yet. Sorry.
This is what I'm getting if it helps.
http-01 challenge for fakedomain.com
Waiting for verification...
Cleaning up challenges
Failed authorization procedure. fakedomain.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://fakedomain.com/.well-known/acme-challenge/XxX1234ABCdefg: Timeout during connect (likely firewall problem)
That means the letsencrypt server failed to connect to your server. HTTP means port 80. So you need to allow incoming connection to your server on port 80 from whatever hostname or IP the letsencrypt server is.
You can disable your iptables firewall, run the script, and enable iptables again after the script's successfully gotten your letsencrypt TLS cert.
Alternately, just have webmin get the letsencrypt TLS certs for you, webmin has the ability.
That's what I thought too. I tried service iptables stop then running it again without success. I don't think Let's Encrypt gives out the IP addresses as they can change and I don't know the name of the host to give exception.
I have tried to install incrediblePBX on ubuntu 18.04 64bit.
but it seems not installed.
Is it cannot install on 64bit? only 32bit?
Sure it does. I installed IncrediblePBX on Ubuntu 18.04 64 bit just this past week.
Does it have something need notice?
I have do step by step
But it seems something cannot install.
In my case I installed IncrediblePBX using the instructions found at this link:
http://nerdvittles.com/?p=25930
... on a VPS instance of an Ubuntu 18.04 64 bit server hosted at Cloud at Cost (not recommended as a provider, but it is what I have). I did this within the past 7 days. It installed fine and works fine.
So, without specific details as to how it is failing at your end I don't know why it is not working for you.
I was able to install an SSL certificate after manually applying these iptable rules:
iptables -P INPUT ACCEPT
iptables -P OUTPUT ACCEPT
iptables -P FORWARD ACCEPT
iptables -F
This actually disables the firewall and can be confirmed by pbxstatus. If you do service iptables stop, pbxstatus still shows the firewall being up. Once I was able to get my certificate, I just used iptables-restart. You may need to also stop Apache prior to certificate request.
hello everyone,
i have installed asterisk on ubuntu server 32 bit.
when i try to get into CLI by typing asterisk -r, asterisk stopped and I get an error as
"Unable to connect to remote asterisk (does /var/run/asterisk/asterisk/ctl exist?)"
when i tried amportal restart, i got
root@mutluPbx:/var/log/asterisk# amportal restart
Please wait...
!!!!amportal is depreciated. Please use fwconsole!!!!
forwarding all commands to 'fwconsole'
Running Incredible PBX shutdown...
[Whoops\Exception\ErrorException]
fclose() expects parameter 1 to be resource, boolean given
restart [-i|--immediate] [args1] ... [argsN]
any help would be highly appreciated.
thanks in advance...
as far as i know and also as you can see in previous comments, you will have to use 64 bit version of Ubuntu
hello Everyone,
PBX is working but web GUI does not show up
I can connect the PBX server via SSH
when I try to update freePBX I got the error attached.
also apache is DOWN.
what would be the reason?
thanks in advance for your help.
