I recently took advantage of the HiFormance deal, which is great! I've been playing around with Incredible PBX and it's cool system. Inbound/outbound calls with my GV number works perfectly. However, I cannot get the voicemail to work and call recordings are non existent.
Issue 1 - GV-SIP No Voicemail
My GV account shows 2 Obitalk entries. First one shows GV1XXXXXXXXX and the other one simply shows Obitalk Device. If both of them are unchecked I can continue to make outbound calls. Inbound calls don't ring my phone and my GV voicemail picks up about 30 seconds in. I then receive a missed phone call email. In order for inbound calls to work I need to have both Obitalk Talk devices checked, but then my Incredible PBX voicemail doesn't pick up.
My settings for this extension (702) are as follows.
Extensions>Voicemail - Snapshot here
Extensions> Find Me/Follow Me - Snapshot here (NOTE: Despite having a ring time of 30 seconds, inbound calls always cut off at the 20 second mark)
Extensions>Available- Snapshot here
Settings>Voicemail Admin - No changes made
I confirmed that the unavail and busy recordings are located in /var/spool/asterisk/voicemail/default/702. There are 2 recordings of each type with the only thing being different is the file extension being capitalized.
Unless I'm missing a setting somewhere, there should be no reason why the voicemail shouldn't pick up and then email me the recording.
Does anybody know if there is a setting I missed somewhere or something else I should check for in the logs?
Issue 2 - No Call Recordings
UCP shows all of my calls in "Call History" and "Call Event Logs" However, there are no links to the actual call recordings.
Applications>Call Recordings is set as follows
Description- 702
Call Recording Mode- Force
Destination- Extensions 702
Outbound Routes-GVSIP-Host-Out
Additional Settings>Call Recording= Force
Inbound Routes-Destination set to trunk:freepbx-remote server (sip)
Other>Call Recording=Force
Enable Superfecta Lookup=Yes
Superfect Scheme=All
Extensions-702
Advanced>Recording Options= Force selected for All, Disabled on Demand Recording, Record Priority Policy= 10
Does anybody have any ideas on how to fix the call recording feature?
Thank you for your time.
Description- 702
Extensions-702
