GO HERE Cache phone numbers to Asterisk phonebook
I have looked at the post on nerdvittles about how to block spam callers.... it says that a cost effective method is to look up the caller id in the asterisk phone book first, and it is very effective if you are caching numbers to the phone book...
How do you cache numbers to the phone book? I cant find a setting for that, or found any forum posts that mention it.... is it supposed to be automatic?
Ok... does this work for the raspberry pi version? I see these lines in the directions:
"We would caution you about using this except on Incredible PBX 13-13 servers running under CentOS 6 or 7 or Ubuntu 18.04 with Signature Checking Disabled. It will trigger nasty signature checking errors on the FreePBX Dashboard."
I don't want to foul up the system...
Should be fine with Incredible PBX 13 for Raspberry Pi.
