QUESTION Incrediblepbx Stops Working After Power Failure
dryce
I am using Incrediblepbx on a Raspberry Pi 3B+. The system works great except following a power failure. Instead of reconnecting, it will cause incoming and outgoing calls to fail until I reboot. Everything shows as connected and Anveo can still see the Sip as connected. I haven't seen anything remarkable in the logs either. Anyone else experience this and have a potential solution?
Sounds like your Pi is coming up faster than your internet connection. Put a sleep delay in the boot up sequence somewhere for a minute before the NIC initializes?
Thanks. I'll give that a try.
