TIPS OBI202 as SIP Extension - REG:NoResp
Jacob Reider
Pulling my hair out ..
IncrediblePBX 13.0.192.19 - running well in the cloud.
OBI202 is behind a Unifi USG AND a Google Wifi router/AP. It works fine with google voice. I can register desk phones and Grandstream ATAs here without difficulty
I want to use one of my OBI202 lines as an extension - basically as a generic ATA. Seems straightforward.
a) Create Extension
b) OBI ==> define the pbx, add u/p .. "registering .." (forever)
c) So I went in to expert mode .. tried to enter it all there and overrode a few defaults .. same.
Watching OBI logs - I see "REG:NoResp" every minute or so ..
Watching server logs - I don't see anything suspicious.
I disabled iptables entirely for a few minutes on the server. No change.
Ideas? I feel like I'm missing something easy.
What does the Asterisk CLI show when you attempt to register from the OBi?
CLI (excerpts) .. u/p is correct .. hmm ..
REGISTER sip:pbx.salundo.com:5060 SIP/2.0
CSeq: 62481 REGISTER
From: <sip:p[email protected]>;tag=SP4f57e3e3293a73832
Contact: <sip:[email protected]:5083>;expires=60;+sip.instance=..
Reply:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 192.168.86.111:5083;branch=z9hG4bK-9fed404a;received=##.244.115.72;rport=5083
Then the password for the account on your OBi doesn't match the password you set up on the Asterisk side.
Heh - agree that's the error .. but I've typed it in eleventeen times .. even cut/paste .. same thing. Works fine on Grandstream ATA. Any idea why OBI isn't seeing the response?
RandomPerson
