SOLVED New 18.04 install broken ?
Status
Not open for further replies.
msatt
Followed https://nerdvittles.com/?p=25930
Web GUI not displaying (php7.2 was installed)
ppa:ondrej NOT installed - installed manually as add-apt-repository NOT installed
Downgraded php to 5.6 and GUI displays with error "file(/etc/amportal.conf): failed to open stream: No such file or directory"
amportal exists in /var/lib/asterisk/bin/amportal (but not in path)
Incredible PBX 13-13.7 for Ubuntu 18.04
Asterisk: UP Apache: UP MySQL: UP
SendMail: UP IPtables: UP SSH: UP
GVSIPNAF: UP PortKnock: UP NR VPN: UP
FaxGetty: DN IAX Modem: DN HylaFax: DN
RAM:96872 18.04 (Bionic Beaver) Disk:3.6G
Asterisk 13.22.0 IncredibleGUI 13.0.120.10
Private IP: x.x.x.x
Public Info: x.x.x.x
System Time: Tue 18 Jun 16:46:13 BST 2019
< OK >
Tried installing Enchilada-upgrade.sh and got downgraded ?
Incredible PBX 13-12.3 for Ubuntu 18.04
RAM:380048 18.04 (Bionic Beaver)
Disk:3.4G
Private IP: x.x.x.x
94%
< OK >
Could do with some pointers - thanks.
I used the same tutorial to do an install on a Vultr VPS and it works fine. Try a re-install?
Thanks Rob - just read some comments at the bottom of the thread saying 4.15 Kernel does not work and that is what I have :-(
Problem is you follow the article and the bit that says it wont work is at the bottom.
Updated to newer kernel (4.19) but the install still fails in the same way i.e. no amportal, GUI fails (wrong php version), asterisk working.
This is running on a kvm in the cloud.
Going through thousands of lines of debug for kernel 4.15 - first failures seem to start with
dpkg: libjack-jackd2-0:amd64: dependency problems, but removing anyway as you requested:
librtmidi4:amd64 depends on libjack-jackd2-0 (>= 1.9.10+20150825) | libjack-0.125; however:
Package libjack-jackd2-0:amd64 is to be removed.
Package libjack-0.125 is not installed.
Package libjack-jackd2-0:amd64 which provides libjack-0.125 is to be removed.
libfluidsynth1:amd64 depends on libjack-jackd2-0 (>= 1.9.10+20150825) | libjack-0.125; however:
libcsound64-6.0 depends on libjack-jackd2-0 (>= 1.9.10+20150825) | libjack-0.125; however:
later
make[2]: Entering directory '/usr/src/linux-headers-4.15.0-22-generic'
INSTALL /usr/src/dahdi-linux-complete-3.0.0+3.0.0/linux/drivers/dahdi/dahdi.ko
At main.c:160:
- SSL error:02001002:system library:fopen:No such file or directory: ../crypto/bio/bss_file.c:72
- SSL error:2006D080:BIO routines:BIO_new_file:no such file: ../crypto/bio/bss_file.c:79
sign-file: certs/signing_key.pem: No such file or directory
INSTALL /usr/src/dahdi-linux-complete-3.0.0+3.0.0/linux/drivers/dahdi/dahdi_dynamic.ko
etc
I have reinstalled MANY times and result is always the same - BROKEN.
Unfortunately, all of you are discovering why CentOS is a safer bet with Asterisk and FreePBX. We will work on this, but the fixes usually last a couple months until something else comes unglued. From our perspective, this is the major drawback of many open source projects. Too many cooks in the kitchen!
later
etc
Maybe, a very big MAYBE, this info will help.
There is no reason to install DAHDI on a cloud server. It is only used for TDM/analog cards that you would install in a physical server. I would propose that install scripts by default should not include DAHDI as nowadays most people are installing to cloud or physical servers without interface cards.
Agree with @billsimon, dahdi problems seem creep up every now and then. Avoid the issue for probably 95+% of installs.
If you don't want to abandon completely, ask the question if installing on bare metal and break all the dahdi building out to a separate script for easier debug/maintenance.
I think virt-what should be available if not installed on all supported platforms.
Follow the tutorial. Use Ubuntu 18..04 (64-bit) platform. Tested on Vultr, and it installs perfectly. If you make "improvements" then it's up to you to fix any problems which result. We have no way to troubleshoot anything other than the advertised platform.
Status
