FYI Do you want a list of your let's encypt certs?
big charlie
You guys already know about this?
This may be usefully and/or scary. Enter a domain and you get a list of certs on it, incl subdomains. So if you have subdomains that you think are hidden, they can be found here.
Could be an argument for wildcard certs, but best assumption is anything publicly accessible will be found.
I'm a liitle confused here, do you guys think that a valid ssl/tsl certificate is to protect yourselves?
(It is vise versa)
How has anybody used these public records of certs (which by definition need to be public), to find a hostname of any ip that acceptably uses it?
Bigger problem, if you loose control of a wildcard cart, all your stuff is exposed
(It is vise versa)
I'm not saying anything other than wildcard as an option if the dns name being exposed via the certificate concerns you.
Outside of temp/test scenarios, I don't use wildcard certs.
If a system is on the net, assume it will be discovered and probed.
Also, it should be noted the information is not limited to letsencrypt certs. Thread title implies this is a letsencrypt "issue." It isn't - it applies to all certs - just the way things are.
Well, I would agree, but the concept of expecting a 'cert' to be in any way 'anonymous' is to me just plain wtf bizarre
Very little is anonymous these days.
I think finding out "some.obscure.hostname.mydomain.com" is so easily discovered was the shock. Security through obscurity is foolhardy, but I can understand the reaction once faced with the reality check.
A lot of folks who should know better are surprised at how much info is readily available for free at sites like censys.io or shodan.io with google search simplicity.
