wardmundy
Nerd Uno
- Oct 12, 2007
- 20,217
- 5,974
Debian version was at 10.1. Commented out the section as suggested and it installed just fine. It didn't automatically upgrade to 10.7 after reboot so I did it manually.Check /etc/debian_version for the version of Debian on your platform. If it's greater than 10.1, the script should run. If you want to eliminate the error check and see if it will work, comment out the section beginning at line 88 of the script through the fi line.
Problem solved, working great. The remote access is wonderful. Having a remote extension working all the time is great. I had been using the 3cx pbx just for the remote now I dont need it all. Thanks again Ward.One problem I had not anticipated is that the office Fortigate firewall refuses to allow connection to dynamic dns sites without specific approval. So no getting my setup working on the long weekend.
On a debian system, you can find these rules saved at the following location:some told me how I delete tehe all IPtables, Incredible conme with many IP address
/etc/iptables/rules.v4
It should be pretty self-explanatory from there.
when make a new installe of Incredible PBX and you check iptables -nL show many IPS ready in the PBX, my question is, they is part of PBXOn a debian system, you can find these rules saved at the following location:
Live Chat
Video Conferencing
Check your inbox!
