FOOD FOR THOUGHT Enable HTTPS with Let's Encrypt
That's the goal.
I'd suggest testing with
fwconsole cert --updateall --force
but @wardmundy has certman locked to an old version that doesn't support --force.
Ok @jerrm , I'll sit back and 'watch'! fingers crossed...
Ha, guess I can't force it then lol
My VPS at CrownCloud is:
Incredible PBX/FAX 2020.1 for CentOS 7
Asterisk: UP Apache: UP MySQL: UP
SendMail: UP IPtables: UP SSH: UP
UCP Dmon: UP PortKnock: UP NR VPN: UP
FaxGetty: DN IAX Modem: DN HylaFax: DN
RAM:97MB CentOS Rel. 7.8.2003 Disk:8.4GB
Asterisk 16.12.0 Incredible GUI 15.0.12.40
Private IP: XXX.XXX.XXX.XXX
Public Info: XXX.XXX.XXX.XXX
System Time: Sat Jan 16 17:55:29 MST 2021
It looks like the ClearlyIP mirrors break specifying a module version with --tag in fwconsole, but you can trick the GUI into upgrading from 15.0.23 to the current version:
Module Admin->​
Check Online->​
Expand "Certificate Manager"->​
Select Previous​
and then "Rollback" to the current 15.0.37 version.​
You'll get improved error messages, --force support, alternate name support, expanded fwconsole CLI support, and a few other tidbits.
Module Admin->​
Check Online->​
Select Previous​
Thanks for this @jerrm ,
So I did :
Module Admin->
Check Online->
Select Previous
BUT DID NOT DO THIS YET:
Because, I wanted to see what would happen when I wake up this morning since me LE cert is now 6 days from expiring...
This is what I saw on my IncrediblePBX dashboard:
!Security Issue !
Some Certificates are expiring or have expired
This is a critical issue and should be resolved urgently
"There was an error updating certificate "mypbx.com": Error 'Token did not match' when requesting http://mypbx.com/.freepbx-known/b3c3255658121d8e22859dbcf60853e1"
(Where mypbx.com is my actual PBX FQDN - I just omitted it here)
Soooo, no what? lol
That implies lewatch let the mirror1.freepbx.org's lechecker.php process through the firewall, but there was an issue with the lechecker token file.
Post output:
ls -al /var/www/html/.freepbx-known
echo cat
cat /var/www/html/.freepbx-known/*
echo ""
echo curl fqdn
curl   "http://mypbx.com/.freepbx-known/b3c3255658121d8e22859dbcf60853e1"
echo ""
echo curl localhost
curl   "http://127.0.0.1/.freepbx-known/b3c3255658121d8e22859dbcf60853e1"
echo ""
Post output:
echo cat
echo ""
echo curl fqdn
echo ""
echo curl localhost
echo ""
ok @jerrm , thanks for at least conforming that lewatch is working ha!
So, any idea what I should try next?
Thank you
Prits
I'd like to see the requested output first, but I would next try from the command line running as asterisk:
su asterisk -c 'fwconsole cert --updateall'
--force shouldn't be needed now that the cert has aged enough.
@jerrm , Here is what I got at the command line:
root@pbx1:~ $ su asterisk -c 'fwconsole cert --updateall'
Certificate named "default" is valid
There was an error updating certificate "mypbxdomain.com": Error 'Token did not match' when requesting http://mypbxdomain.com/.freepbx-known/5a7febc0660a2eb4475ddc92e0d08c2e
root@pbx1:~ $
root@pbx1:~ $
Post output of:
curl "http://127.0.0.1/.freepbx-known/5a7febc0660a2eb4475ddc92e0d08c2e"
Sorry for the delay @jerrm , here it is:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>301 Moved Permanently</title>
</head><body>
<h1>Moved Permanently</h1>
<p>The document has moved <a href="https://127.0.0.1/.freepbx-known/5a7febc0660a2eb4475ddc92e0d08c2e">here</a>.</p>
</body></html>
Looks like you have port http requests redirected to https. That may very well break the mirror's lechecker.php process it is not following location. It's expecting a token and getting the above message. Not sure about LetsEncrypt itself and the Lescript.php library.
Post the apache config you are using for the redirect so I can test the equivalent.
Ok @jerrm
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule ^(.*)$ https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
and I did mention my system in message #41
I did not upgrade to Incredible 2021 - PUBLIC
Here it is again just in case sir:
RAM:78MB CentOS Rel. 7.8.2003 Disk:8.4GB
Private IP: Hidden
Public Info: Hidden
System Time: Mon Jan 18 18:42:40 MST 2021
< OK >
But left out the fact apache was not in a standard config.
It's definitely the redirect, I assume it was added after the cert was initially generated? Don't disable yet, let me test if it's an lechecker only issue or if it will also be an issue with the Lescript.php library. If lechecker only, my pending pull request for certman will probably let the process complete.
RewriteEngine On
Change to:
RewriteEngine On
RewriteCond %{REQUEST_URI} !^/\.(well-known|freepbx-known)/
Change to:
RewriteEngine On
@jerrm , I change it to the above, will update you tomorrow sometime once I have checked if the LE cert updated overnight.
Hello @jerrm , I am pleased to report that it worked! Woke up this morning to see that the LE cert had renewed!!!
Thank you so much for the LEwatch script and your guidance here!
@Prits
lluis.riera
