That you 'don't think so' is just your opinion, mine is that without doubt these guys are using a 'Command and Control' system that duck's and dives identification, (think botnet), what you are seeing is just today's throwaway 'mules' IP's which are cheaper if bought by the bunch .
So far it's not worth their effort to look further than UDP/5060 , that's called the 'low hanging fruit' and where many of you un-illuminated guys are hanging, (do you still have sshd on 22? ) .
So, if you guys are still using UDP/5060? I will 99.99% guarantee that you will continue with that
So, if you guys are still using UDP/5060? I will 99.99% guarantee that you will continue with that \ problem. If on the other hand you don't you will no longer experience this stuff.
As the doctor said to the patient saying "It hurts every time If do that" with " Then stop doing that"
(Just try it . . .)
l
(Just try it . . .)
