411 Directory Not Working
lunitin
PBX in a flash v. 1.3 installed last week with all updates. FreePBX 2.4.1.1. Status shows everything ONLINE except Samba.
I am probably missing something simple, but I can't seem to spot it. When I dial 411, or the directory from the IVR I get the prompts but can't find any users. 0 also won't dial the operator ring group. In both cases it says no directory entries match your search.
All voicemail boxes are in the default context.
Under the extensions the voicemail status is set to Enable
In the IVR the Directory Context is set to default.
Under General Settings "Find users in the Company Directory" is set to first and last name, the operator extension is set to the 602 ring group.
I can manually dial the 602 ring group without any issue.
Not sure if this is related but I have the Aastra 57i scripts. If I press the Directory button on a 57i, all of my users are displayed and can be dialed without issue.
I have the exact same problem
Same thing with PiaF 1.2 - Need to fix for a customer installation.
Should I be setting up the users in another location for them to be found?
TomS
Hey Tom,
I discovered that my problems are rooted in the directory script itself, called pbdirectory. Located in /var/lib/asterisk/agi-bin/
1. It incorrectly parses the phone book when it loads, resulting in no entries found.
2. It is not setup for LAST name search
3. It is not passed the First, Last, Any option that is set within the FreePBX GUI
I have addressed the first two issues, and have been using the hardcoded option for the third. I doubt I will ever change it from Any so this works for me.
Extract the zip into /var/lib/asterisk/agi-bin
If needed, change $dir_type on Line 39 from DIR_ANY to DIR_FIRST, or DIR_LAST depending on your needs.
chmod 555 /var/lib/asterisk/agi-bin/pbdirectory
This makes the file read only, see the comments at the top of the file for reasoning.
Directory still broken?
Hi All,
I just installed PBX in a Flash 1.4 64bit on a new server. I locked down the firewall and then upgraded all FreePBX to 2.6. This is a dual homed server so I firewall nearly everything on the public interface.
I configured my Vitelity trunk and an extension and it's working properly for incoming and outgoing calls.
The only thing I've changed on the General Settings page is the Update E-mail, and I am having problems with the Directory again. With everything at the defaults (Find users by Last Name, Do not Announce Extension, and null for Operator Extension) I cannot find myself in the directory with the first three of my last name, however I can find myself with the first three of my first name.
I haven't found very many other posts with directory issues so I wonder if there is something I did wrong or a setting I am missing for the directory to work properly? Any help would be appreciated.
works on Piaf v1.4 32 bit
Hey Tom,
Thanks for the fix!
