SOLVED Fix for paging and and intercom in I_PBX 2021B1
GerryGerry
Since moving to the latest (albeit beta) version of incredible PBX, paging and intercom has broken. I have traced the problem to the agi scripts using PHP 7.4 which does not allow for array variable to be accesses with curly brackets {} but rather exclusivly square ones [] this cases the agi script to fail. the fix is to edit.
/var/lib/asterisk/agi-bin/phpagi.php with attached version (Rename it without the txt extension).
